Hi all,
I'm going to be upgrading my auto r34 set up and I'm going to install some new gauges. What do people think about prosport gauges ? Also to install the boost gauge can I use any of the factory wires/ connections ?
Lastly does an engine oil temp gauge work for trans temp ?? I can't find any trans temp ones so I was thinking about using an oil gauge and sensor for it ?
Cheers guys
Cheers guys, was just a little unsure. Also oil temp sensor will work yeah ?
Also do I have to run new sensors for the boost gauge and normal engine oil gauge to work or can I tap into anything from the factory set up to save some time ?
Good chance the sensors will be different resistance, you need to put the prosport sensors in for the gauge to be accurate.
Do you have an oil cooler? I run mine in the hoses, same with the auto temp sensor.
Yeah good point. And I'm buying a bigger trans oil cooler http://m.supercheapauto.com.au/Product/Davies-Craig-Hydra-Cool-Transmission-Oil-Cooler-8-Cylinder-Universal/125648 and I'll run the sensor after it before it re enters the transmission but the engine cooling is stock
Basically.
Think about it this way (im going to exagerate alot here). If the oil coming out of the trans is 200 degres, and the oil going into the trans is 50 degrees, which would you rather know about?
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
