FOR SALE
2008 FG XT Ford Falcon
Great reliable tow car
Selling this as i set it up to tow my track car, which i no longer use
Has only been towed with 4 or 5 times.
Great reliable car, never had a mechanical issue's with it.
154xxxK's on the clock
Full service history
Interior is tidy, plenty of room, very comfortable!
Have spent over $2000 to set this car up to legally tow up to 2300kg braked(over ride or electric).
Has Electronic brake controller installed.
2400kg tow bar
Rear towing airbags.
Front mounted PWR transmission oil cooler
Upgraded rear munroe shocks
New roof lining
New front windscreen
Brakes are only a few months old
Remote Central locking
Tinted windows
Rear spolier
16' Alloy wheels with about 75% tread all round
Airconditioning
Has AUX in plug for Stereo.
All original, no Accidents
Now has QLD rego until september, will come with a roadworthy.
Only bad is a small rust bubble in the boot from the spoiler being installed incorrectly from factory.
Please contact me via text or phone call with any further questions!
Price: $8500ono
Located at Balmoral in Brisbane
Contact phone number : 0431143031
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
