Just buy NGK copper plugs from your local auto store/s. Depending on boost levels you may want to run 6 or 7 for your heat range. Usually the plugs come 1.1mm gap, simply gap them down to 0.8mm and put them in.
May as well check your coil packs and ignition leads at the same time to prevent issues during tuning or down the track.
I can tell you right now that you should definitely be pulling more power closer to 300kw if you are using factory injectors/pump (at their limits). Running the 9's at low boost you'll get increased lag, assuming you are chasing response you might want to consider your fuel system options to prevent that. Obviously factory clutch might become an issue possibly unless you put a better one in with the motor out and other issues arise.
Final question, what made you rebuild your rb26 with standard components and not aim for stronger internals or head work?
Cheers for the reply. I was in a bit of a rush with the initial post as the donk is not completely standard. to be honest 300 is the aim I was just being conservative.
it has Forged pistons, upgraded rods, oil restrictor, sump baffle, tomei metal gaskets. its not over the top but should do 300awkw pretty easliy. My goal with the -9's is to run about 20/21 psi as the haltech will do that by default
The clutch has also been sorted. its new and not stock.
Sounds good and perfect for 300kw, nice figure and I am aiming for around 330kw at 20/21psi with my setup once complete. I am also using hks gt-ss's which are -9 equivalent.
But yeah make sure the fuel system and ignition is sorted correctly and you should get good results with the setup you have.
Stock camshafts will still be good but if you put in adjustable cam gears you might of done some camshafts at the same time to give you that increase.
With regards to plugs, there are two types you might need to try to find what works best for you. Consult your engine builder/tuner to see what he might suggest but it is a matter of trial and error really. But if you have new ignition components then you probably won't see any issues.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
