Hey Guys,
just need some advice as im looking at buying an R34 GTT turbo which will supposedly bolt right onto my R33 RB25det without having to change anything.
looking at buying an op6 Turbo but am unsure as to whether this is off an R34 and if it will bolt straight on?
Ive also been told to get the R34 GTT turbo high flowed.
Any help is greatly appreciated.
Cheers.
Yes. It is almost exactly the same turbo. The internals of the OP6 housing are larger than the 21U housing on your std 25 turbo.
A turbo with an OP6 housing is not necessarily an R34 turbo though. The OP6 was also used on VG30 turbos. I suspect the easiest way to tell the difference would be that VGs probably have an alloy compressor and R34s would have a plastic compressor.
For everything you need to know about highflowing these, look at the stickied Hypergear thread.
/searchable topic.
yes, and it's an awesome turbo considering the price tag. Although it doesn't run very well on the standard R33 ecu. I was having issues at 9 psi on the HG 21u highflow
so in other words if you're on the factory ecu stick to the factory r33 turbo. I'm sure the R34 turbo will run okay but it wont be perfect without a tune
yeah i am planning on getting a Nistune ecu as well.. can anyone recommended where to buy Nistune ecu or would you recommended Apexi Power FC and Boost controller ? thanx guys
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
