I have been trying to do this all morning with no luck. I have read how to enter diag. mode but my ecu does not have the selector screw, and also does not have the diag connector. Therefore i cannot enter diag mode.
I dont have any LEDs on the ecu either so i guess i go by the engine check light.
I have a 95mdl GTST, anyone else have this problem?
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/
under the dash on the drivers side there is a connector with 14 pin holes (2 rows of 7 pin holes) in it....looking at the front of the connector with the chamfered end facing the left you need to switch the ignition on and touch the 6th and the 7th wires on the top row together for a second with a paperclip,the vehicle will enter diagnostic mode....
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928326
mine didn't have the LED's but it did have the screw (94 model) where are you looking at the ecu? have you pulled it right out?
on this note i thought it good to mention that when i did mine it came up all good code 55.. but this happened even when i disconnected my injectors, CAS,AFM and water temp sensor.. so i dunno how helpful it is!!
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928600
Thats the problem, there is no connector. Can anyone post a pic of where theirs is?
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928769
Yeah i took the ecu right out and there were 2 holes, possibly where the LEDs go on the other models. Mine just had a blanking sticker over the holes.
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928774
Where are you, i can get hold of a carmen scan tool, does all imports to current models and also displays active data.
Does the scan tool plug into the wiring harness or ecu or both? I would be interested in been shown what it does.
I am in quakers hill, about 25 mins from penrith
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928777
sorry to hijack
but i wanted to get my ecu out to see if it is a stock one or not, cause it doesnt cut out at 180
can anyone help?
ive tried to get the kick panel out but after i take off two screws it is still connected by something else behind it
Mine only had the 1 screw closest to the front near the firewall but has 2 clips that need a good tug to break free. get a commone screwdriver and wedge it between the panel at the back of it, near the door seal.
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928779
i had to lift of the plastic sill (with skyline embossed) then unscrew that plastic nut near the firewall
then i unscrewed one of the dash compartment screws so that i could get it out a bit easier
once i done that it still has a clip of some sort that needs to be undone or something, im guessing that is what needs a good tug?
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-928786
Jason, they ECU has 3 bolts holding it in, one on firewall and two on other end!
Damo, mine has a clear platic sticker with Jap writing over the screw.. it's within the hole and needs a small flat head screw driver! if it has no LED's then just turn clockwise all the way the turn it back!
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-929282
The engine needs to be running. Disconnect Water Temp sender with engine running, then run diagnostics.
https://www.sau.com.au/forums/topic/45503-ecu-diagnostics/#findComment-930091
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
