Hi,
I've got the 25-GT auto, and I've been having problems with my instrument cluster lately. The speedo, tacho, and odometers don't work properly.
Normally when I start the car, especially for the first start of the day, the instruments don't work for a good 20 minutes of driving, before they start working again. This has been ongoing for more than a month, it first started when I was driving on an error 21 code, which I resolved last week by changing the coils, though it has gotten worse and worse recently, taking longer time for the sensor to start working. The last time I filled up, the speedo and tachometers didn't work after I started the engine, and the fuel gauge also didn't update until the other instruments started working.
Today I was driving without the instruments working and the engine light came on, it went off again as soon as the instruments started working and then came back on later when they weren't, only to disappear once again when the instruments started working again. I got home and plugged in the scanner, I got Error 14 P0500. So I've obviously got an issue with the vehicle speed sensor.
What I wanted to ask was if the speed sensor from a RB25DET is compatible with the RB25DE engine I've got?
Also, would it be worth my while to get it checked out by a mechanic or should I go ahead and purchase a new speed sensor? I read that this fault can be thrown by loose wiring and other causes, I might not have to change the speed sensor but as it has been a problem for over a month I'm not sure if I will luck out with it only being a wiring issue. I'm in a bit of a tight situation financially as I've just had to spend a substantial amount of money on the coils and the labour so I'm looking to avoid having to purchase a new sensor until I'm certain it needs to be replaced. Would there be any easy way to check myself if it's a wiring problem? I'm absolutely hopeless mechanically so anything more than opening up the hood won't work for me. I was thinking I could try connecting to my scanner while driving without the speedo working and checking via my phone's Consult app to see if the ECU is still putting out a proper speed reading, which might indicate that it's a wiring problem.
Thanks
Edited by Wordsmith
https://www.sau.com.au/forums/topic/455098-r34-speed-sensor-issue-error-14/
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
