Engine
SR20DET
Tomei Poncams
Trust T517z 8cm
6Boost Manifold
770cc Injectors
Z32 AFM
Power FC
Metal Intake Pipe
Greddy FMIC
B&M Oil Cooler with Relocator
Yashio Factory Radiator
Cusco Catch Can
Rocker Arm Stoppers
Full HKS Turbo Back Exhaust
Hi Flow Cat
NPC Cushion Button Clutch
Gktech Clutch Fan and BMC stopper
Suspension
ISC N1 Coilovers
S15 5 Stud Conversion
Castor Rods
Tein Inner & Outer Tie Rod Kit
Rear Camber Arms
Rear Toe Rods
Whiteline Rear Swaybar
New front swaybar links and bushes
Alloy Subframe Bushes
Urethane Gearbox Mount
Engine Bash Plate
Front Tension Brace
F + R Strut Braces
Cusco 1.5way 4.1 R200 LSD
R33 5 bolt half shafts.
Interior
R33 GTR Seats
4 Apexi EL Gauges
Apexi AVCR
Apexi Power FC + Handcontroller
C Pillar Brace
Exterior
Volk Rays TE37's 17x9.5 +12 - 18x9.5 +12
Full Type X Aero
Topstage Front Lip
Clear Headlight Lenses
8000k HID's
Carbon Roof Wing
290hp on 17psi. Tuned by 101 Motorsport Brisbane.
$18000. Rego and RWC neg
Not the everyday run of the mill 180sx.
This is an extremely tidy 1996 example with only 66000km.
Genuine interest only. No rush to sell. Interstate shipping can be arranged for under $700.
I have owned this car for the past 5 years (since stock), and all modifications have been added within the last 10,000km.
Located in Macleod, Melbourne.
More photos available on my instagram: benomoore
Build Thread: http://forum.jdmstyletuning.com/showthread.php?29269-Ben-s-Kouki-180sx-that-90-s-style
Edited by drf7r
  • 4 weeks later...
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
