Hey guys, I've got an R33 with an RB25de neo, my coil packs weren't sparking under load so I changed them to super sparks & they ran great for about a week & I started getting a misfire so I pulled them out checked them, changed plugs & then put it all back and now it misfires when it's cold & misfires every now & then. I've changed fuel filter aswell (had a service) Not sure what it could be. Also have a flat spot after i downshift & accelerate or when I put my foot flat it hesitates. I've searched the web like crazy, can anyone help?
Thanks everyone!
https://www.sau.com.au/forums/topic/455130-help-misfire-flat-spot-rb25de-neo/
Found the problem all been fixed!
#6 coil pack was misfiring intermittent so I couldn't find it but done a lucky coil test last night & found it!
As for the flat spot, when the previous owner swapped the engine he left the r33 loom & turbo ECU in the car.[emoji50]
It's booked in for a harness & ECU conversion early May!
  • 6 months later...
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
    • 75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive.
    • Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
