Now that I've got one of these Ecu's in my car I've been slowly getting familiar with the VE approach to tuning. Searched as I have, I've not seen a thread with much useful information, and certainly nothing with any cool tricks or FAQ.
So let it begin. If you come up with a unique solution or trick then post it up.
Got a question, post it up. Know the answer... post it up!
Automatic Cell Tracking
The first thing with the Haltech that I noticed is that it wont "align" to the current load point without you first pressing the space bar. This is a bit annoying for me, as I have always used this feature when performing light load tuning corrections when road tuning. I normally do this with a wireless mouse that has extra programmable buttons to send increase/decrease current cell keystrokes.
I found the solution to get that capability here in a program called X-Mouse.
http://www.howtogeek.com/howto/14400/use-those-extra-mouse-buttons-to-increase-efficiency/
This program allows you to map a sequence of simulated key strokes to the extra mouse buttons on any mouse.
Variable fuel pump speed control
I've upgraded my fuel pump setup, and wanted a method to control the fuel pump speeds so they dont run flat out the whole time. There are a few benefits to this. The main ones are cooler fuel, less power consumption and electrical system load, and the capability to run smaller supply, regulator, and return lines for the pressure circult.
I have used a pair of solid state relays which are driven by a pair of DPO outputs. The outputs are controlled by a table that uses the Fuel Pump signal as one axis, and the other axis linked to Injector 1 duty cycle. Fuel pump speed is ramped from 30 at idle to 100% at 70% injector duty. It works a treat for the lift pumps and the main pressure pump. The Holly 1800 remains at near ambient temps to the touch.
The map is set such that if the duty is at 0, but the pump is on duty will be at 100% so the fuel system will prime. Once duty is > 1%, fuel pump speed becomes variable and dependant entirely on duty.
As the motors are an inductive device, a 1n4004 diode must be wired across the fuel pump motor. Otherwise a high voltage spike will kill the solid state relay as it is switched on and off at high frequency.
Thanks to Mitch at Haltech for assisting with the mapping for the PWM DPO's.
Everyone feel free to contribute.
  • Like 3
https://www.sau.com.au/forums/topic/455135-the-haltech-platinum-pro-thread/
I'm in on this as well.
Pulsed out fuel pumps! Sweet!
I am still building my engine and i just started going through haltech software for mine. What kind of IO are you using for boost control and which solenoid?
Also what kind of IO board are you using for the fuel pump pulsed outs?
I'm quickly realizing the power of this ecu!
So Fuel Lab have built solid state relays into their pumps. Pretty clever and yes it should work too without the need for a solid state relay to drive it.
There isn't much info at all on their electronic regulators though other than that they contain a PWM controller in the base. Shame it will be mounted at the wrong end of the car to easily connect to the pump.
    • Each province differs a bit but we only do mandatory vehicle inspections here for heavy vehicles (Think Ford F350 and up). Those inspections are done by mechanics that are approved by the government. Besides that, it's a free for all as long as the car looks stock.  I asked because I love seeing how engineering differs from country to country. Here in Canada, all designs must be stamped and signed before they can be brought to fruition. (I.E Bridges, structures, Electrical panels, machines, literally everything shy of a wooden table) This can only be done by a professional engineer or professional engineering technologist. Both are protected titles, but the latter having more of a limited scope in what they can stamp. To become a professional engineer, you must complete a 4-5 year bachelors degree in your field of engineering, be part of an engineering order and undergo 4 years of apprenticeship, testing and mandatory continues education. Same story for engineering technologists, but a 3 year associates degree in some form of engineering technology will suffice. If you do not comply, or pretend you're an engineer or technologist, off to jail you go. If you stamp a design that fails, off to jail you go. If you stamp a design that fails and kills someone (I.E Bridge collapse) Off to jail you go for a very long time, your family will be ridiculed on the news, neighbours will surround your home with pitch forks and your dog will disown you.  Same for specialised trades... Example Electricians must undergo 1.5 years of post high school education, 4 years of apprenticeship, testing and hold proper licences. It's for the best, but then we also wonder why we're so short on engineers and tradesmen haha
    • Not currently, I'm at the school where we teach people to build bridges and other fun things that involve making, or breaking things
    • I have a friend who has used Chequered Tuning and CMS. Went to CMS when Chequered had a long wait time which is kind of the norm (for good reason). Was very happy - I'm pretty sure the very simple thing you're asking will be simple.
    • lol that caught up a year quickly! good to see you on the track again, hoping to do it myself one day
    • Nah he was mega organised, the sort of guy that put (almost) every tool back every day, it made trying to work out where things were up to possible.  My shed needs a swedish death clean, I would have >20 part done jobs, its particularly hard to collect all required parts for a job ahead of time when you can't just pop into a shop and grab things
