Well for starters if its ball bearing you aren't going to be able to rebuild it unless you can source the correct bearings which would be proven difficult. Alternatively you'd have to buy a new cartridge which is pretty expensive also.
Might be best to contact Tao from Hyper gear to see what he can do for you.
Hi does anybody know if its possible / easy to put new bearings in a garret gt30r turbo? I have one with noisy bearings due to being on a car with incorrectly set up oil drain.
Has anyone here just fitted new bearings?
New core as above, you should be able to swap the CHRA yourself.
Sounds like your oil feed was insufficient, the drain being blocked wouldn't starve the bearings, it would just push oil out the seals and blow smoke.
