Rb26 Twin Turbo Upgrade Specifications - Would Like Specifics With Models, Sizes Etc
-5s + 3L will do it easy haha
If it was a dirty old BNR32 or BNR33 I would go 3L but I want to keep the GTR about it lol.
Mafia, are you planning on stroking this at any stage or strictly a stock engined car? If not, a set of -5's and a step 1 v cam which you can use with stock pistons will definitely help you reach your goals.
Stock at the moment. Considered adjusting cams but funds aren't that plentiful at the moment. I'm just chasing replacements for my -5s.
This is what ATP have said. Looks like they only have options for the GTX2863 and GTX2867 at the moment which are too large for what I want.
Hello Jonathan,
Thank you for contacting us. We offer the GTX2863R and GTX2867R upgrade solutions to the stock turbochargers. The turbine and compressor housings bolt-on to the stock compressor inlet, turbine inlet, and turbine outlet.
Product details (NOTE: GTX2863R and GTX2867R are upgrade options under related parts):
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=GRT-TBO-075&Category_Code=RB26
Feel free to contact us for further questions.
Thank you
Doesn't look like they offer a solution:
Hello Jonathan,
We do not offer a bolt-on solution for the GTX2860R.
The provided link is a GT2871R with the option to upgrade to the GTX2863R and GTX2867R. The GTX2863R and GTX2867R are the only available GTX series options within the Skyline housings.
Thank you
I've added the GTX2863 to my cheat sheet. It looks like it was made to be the -5 equivalent.
Does anyone think the different lower trim would help it spool? Need some experts in here to talk to me about the specs :)
ATP are pretty helpful, they just sent this:
Hello Jonathan,
No problem. On a typical 2.0L setup, the GTX2863R spools about 100 to 150rpm slower than the GTX2860R.
Simon did a back to back with -5's and 63 mm GTX wheels in -5 housings. Made an extra 90 hp through the middle and 50 up top or so. I have the graph in my phone somewhere. I'll post it up this arvo after work. That was on a RP 2.8 though.
I'm sure those results are on the GTX thread. Go back about 12 months.
That's a really nice plot. Can anyone give an idea of what rpm vs speed between 90 and 130?
See with this sort of upgrade, the GTX2860 (Slightly smaller) would be earlier and even more responsive with a nice top end
I've plotted it over my graph which has rpm. I'll dig it up tomorrow for you.
They are on 2.8's though.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
