I need a set of standard shockies to pass an inspection.
Does anyone have a set to sell to me?
Or what other model Nissans are the same as the 02'-06' 350GT Sedan that I could buy from eBay & Repco?
Many thanks in advance for the info... A+
Greatly Appreciated.
Edited by PaulReeves.com - GPOWER.TV
Do you have the shockie strut mounts for the Skyline 350GT Sedan as well but AsM?
And were you wanting to sell them or hire them out incase you need them back when you sell or trade your car in?
sorry not sure what u mean by shockie strut mounts? do you mean the tops that attach the top part of the strut to the car?
Yes those ones.
Like this eBay item #230841054853 from UK.
How much for yours if you hire them or sell them to me?
Yes those ones.
yeah mate those are the oem tops and what i have is complete set with the tops / springs n all.
I am trying to figure out the Left & Right sides from the rear set of shock absorbers.
Part Numbers are: 3212 56210CD021 & 3211 56210CD021
Anyone know the answer?
All sedans take the same suspension 250/300/350GT manual or Auto are all the same.
Did the manuals (and maybe option on the auto), have 'sports' suspension with red tokico shock absorbers and firmer springs? where as the standard shocks were black.
  • Like 1
I am fairly sure the rears are identical. there is nothing different between left and right.
Fronts are different though!
  • Like 1
Yes I think you might be right Greg as they had nothing different.
Wherase the fronts only goes in one way!
Adelaide Regency inspection ready!!! :)
SA Regency Inspection failed me on Friday even with the stock suspension installed because it was used & not in near new condition.
Which resulted in it sitting 9mm lower than normal! :(
The Brisbane SAU Member sold me 350Z Suspension ($578), not the 370GT Suspension as we agreed on...
Hope PayPal can fix him up a little bit!!!
Anyway I failed the Full Roadworthy last Friday morning on the Middle Seat Child Restraint Bolt not being present (BOSE Sound System is in the way).
Tint was too dark at the front (even though I asked for darkest legal tint, work that out)!!!
Rear ride height is sitting too low (9mm) from minimum allowable.
HID bulbs (which was the only thing I was afraid of failing on)!!!
And to top it off the Import Factory in SA hasn't got my Model Coil Springs!!! :(
So I can't do nothing to pass SA anymore...
Did some quick research:
http://www.raa.com.au/documents/motoring-window-tinting-factsheet
Front windscreen The front windscreen of a vehicle must have a luminous transmittance (or visible light transmission) of at least: 75% for a motor vehicle built after 1971; 70% for any other vehicle. The windscreen must not be coated in a way that reduces its luminous transmittance in any part of the top of the windscreen wipers’ sweep or the upper 10% of the windscreen; whichever is the lesser.
Meanwhile in NSW we are not allowed to tint the front windscreen AT ALL. Seriously why tint the front anyway?
HID always has issues because if your car does not have washers and adjustable projecting equipments, even if HID is stock it will still be against the law.
  • Like 1
:) I assumed he meant front side windows.. not windscreen.
When you said you got '350z suspension' do you mean springs as well? as they will drop a sedan about 25mm all round.
And at $578 it would want to be in awesome condition!
http://www.ebay.com.au/itm/350z-stock-suspension-/151653477580?pt=LH_DefaultDomain_15&hash=item234f406ccc
Does the factory glass have some amount of tint in it? as that plus T35 film will make it too dark.
  • Like 2
I believe they have "UV cut glass", which I presume is a buzzword for inbuilt tint of some type. The side windows seem pretty dark anyway, and I don't believe mine are tinted...
  • Like 1
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
