I need a set of standard shockies to pass an inspection.
Does anyone have a set to sell to me?
Or what other model Nissans are the same as the 02'-06' 350GT Sedan that I could buy from eBay & Repco?
Many thanks in advance for the info... A+
Greatly Appreciated.
Edited by PaulReeves.com - GPOWER.TV
Do you have the shockie strut mounts for the Skyline 350GT Sedan as well but AsM?
And were you wanting to sell them or hire them out incase you need them back when you sell or trade your car in?
sorry not sure what u mean by shockie strut mounts? do you mean the tops that attach the top part of the strut to the car?
Yes those ones.
Like this eBay item #230841054853 from UK.
How much for yours if you hire them or sell them to me?
Yes those ones.
yeah mate those are the oem tops and what i have is complete set with the tops / springs n all.
I am trying to figure out the Left & Right sides from the rear set of shock absorbers.
Part Numbers are: 3212 56210CD021 & 3211 56210CD021
Anyone know the answer?
All sedans take the same suspension 250/300/350GT manual or Auto are all the same.
Did the manuals (and maybe option on the auto), have 'sports' suspension with red tokico shock absorbers and firmer springs? where as the standard shocks were black.
  • Like 1
I am fairly sure the rears are identical. there is nothing different between left and right.
Fronts are different though!
  • Like 1
Yes I think you might be right Greg as they had nothing different.
Wherase the fronts only goes in one way!
Adelaide Regency inspection ready!!! :)
SA Regency Inspection failed me on Friday even with the stock suspension installed because it was used & not in near new condition.
Which resulted in it sitting 9mm lower than normal! :(
The Brisbane SAU Member sold me 350Z Suspension ($578), not the 370GT Suspension as we agreed on...
Hope PayPal can fix him up a little bit!!!
Anyway I failed the Full Roadworthy last Friday morning on the Middle Seat Child Restraint Bolt not being present (BOSE Sound System is in the way).
Tint was too dark at the front (even though I asked for darkest legal tint, work that out)!!!
Rear ride height is sitting too low (9mm) from minimum allowable.
HID bulbs (which was the only thing I was afraid of failing on)!!!
And to top it off the Import Factory in SA hasn't got my Model Coil Springs!!! :(
So I can't do nothing to pass SA anymore...
Did some quick research:
http://www.raa.com.au/documents/motoring-window-tinting-factsheet
Front windscreen The front windscreen of a vehicle must have a luminous transmittance (or visible light transmission) of at least: 75% for a motor vehicle built after 1971; 70% for any other vehicle. The windscreen must not be coated in a way that reduces its luminous transmittance in any part of the top of the windscreen wipers’ sweep or the upper 10% of the windscreen; whichever is the lesser.
Meanwhile in NSW we are not allowed to tint the front windscreen AT ALL. Seriously why tint the front anyway?
HID always has issues because if your car does not have washers and adjustable projecting equipments, even if HID is stock it will still be against the law.
  • Like 1
:) I assumed he meant front side windows.. not windscreen.
When you said you got '350z suspension' do you mean springs as well? as they will drop a sedan about 25mm all round.
And at $578 it would want to be in awesome condition!
http://www.ebay.com.au/itm/350z-stock-suspension-/151653477580?pt=LH_DefaultDomain_15&hash=item234f406ccc
Does the factory glass have some amount of tint in it? as that plus T35 film will make it too dark.
  • Like 2
I believe they have "UV cut glass", which I presume is a buzzword for inbuilt tint of some type. The side windows seem pretty dark anyway, and I don't believe mine are tinted...
  • Like 1
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
