so i have a slightly new plan after calling up some tuners and having a chat,
going to run a haltech instead of microtech swap out the manual boost control for an electronic duel stage get the new mafless tune and just got for a single 044 intank fuel pump because i dont really need the full fuel set up for a streeter,
now just need to save the pennies!
figured out one of my AFM's is acting up and thats whats messing with the tune so im just geting another pair to wack in and get the car running mint again for the mean time while i save,
also noticed a bit of oil in the intake piping is there a reason to worry? previously had a catch can set up but removed it
soo has anyone had their wiper washer bottle keep draining in less then a hour and not leak out of the bottle at all, im 99% sure theres no leaks out of the bottle pulled it out and tested it and put it back in and filled it up and can watch the water go down but not not a drop in the engine bay under the reservoir ?? so must have a leak in the line right? but i cant see any drops of water come out under the car so not sure if its worth getting too deep looking for it haha.
i might just do a relocation to the boot like this guy
http://www.skylife4ever.com/2011/01/washer-bottle-relocation-and.html
and run the rear wiper spray to the intercooler with all new lines throughout
so im still chasing this little issue before i take it back for a tune, got some second hand AFMs cleaned them and put them in but still have the same issue, they are a lot closer in volts compared to the last pair so im assuming there good and its something else thats causing the miss when boost comes on around 4k maybe spark plugs?? as coil packs are less then 5000 ks old? will get in there in the next couple of days to have a look in the mean time can anyone think of what else could cause this, also just replaced the TPS
Cant help with the miss, but can offer the following.
When the afms get oily it is because the turbo sucks the blowby out of the cam covers, carrying oil with it. If you follow the breather line from the exhaust cam cover it finishes in the suction side of the rear turbo. There is a restrictor in the hose so the suction isn't too much and no one ever changes it when they put bigger turbos on the car.
The other thing that happens is when oil gets on the afm's they measure high. So you get a rich fuel mixture. What is the afr at 4000 rpm and did it change with the change/cleaning of afm's.
Lastly unless there is oil dripping out of the bovs when you leave the car parked you don't have a problem. Even if it does you may not have a problem.
at 4000 rpm the afms are on 2.0 volts, didnt test what they were on with the old afms because they were reading a difference in voltage even on idle so knew one was bad, and i cleaned these ones before putting them in so dont have a reading from before hand, and now the voltage is much closer only ever out by 0.1 V if that so im assuming these are good, and have never had oil dripping out of the bovs before either,
is there really much point in running a catch can set up or is the factory return set up fine?
  • 2 months later...
just gotta get 1 more afm and am just going to get the issue sorted, swap to z32s and a bigger fuel pump which should get to 400hp which will do for now, but first gotta pay rego in like 2 weeks and im now doing uni so my weekly funds from work have become a lot less so might take a month to get around to everything
yeah just for now because i want to get it running mint so it can at least be driven but will go haltech later once i have the money spare, need to sell one of my other cars
  • 10 months later...
Finally got my car back from my tuner after 7 MONTHS! LMFAO (shouldn't have told him im currently unlicensed and to take his time but on the other hand freed up garage space)
managed to acquire a few parts in this time as well
just put in BC BR Gold coilovers so i finally have some adjustability as well as camber arms all round
swapped out the craft square mirrors for some east bears
finally got some plates to match TKR32 - TommyKaira R32
Apexi exhaust
R34 GTR Vspec II front seats (yet to go in)
Greddy Front brakes and Greddy 2 peice rotors  (yet to go in)
GFB G-Force II boost controller
Ended up going with a Microtech LT-16cbecause of the price difference and how much easier they are to tune time wise
Ended up with 400HP at all four which isnt as high as i was after but it is a fairly safe tune with room to tweak with someone who knows GTRs better
Heres some pics with it pretty low and wide since its not getting driven much
  • Like 2
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
