Hello
I need to replace my clutch plate in the r32 GTS-T. I am being given a brand new Nismo Copper Mix clutch plate. Can I use this with the stock clutch cover? Or do I need to use the Nismo one? I would need to buy it.
I already ordered a new release bearing, sleeve, etc for the install.
https://www.sau.com.au/forums/topic/455181-clutch-questions-before-install/
Why wouldn't you get the nismo plate to go with it? You need the nismo clutch cover you can't use the stock one.
I was told that the clutch plate can be used with the stock clutch cover.
So I cannot use the Nismo Clutch Plate without the Nismo Clutch cover? Are the covers different? I thought the Nismo one was only reinforced.
If you install the new plate against the freshly machined flywheel and then you put the old worn pressure plate back over the top can you guess which side will be glazed after a very short use?
You need at the very least a new standard pressure plate. I never asked how the old one came to need replacing and how much power you are putting through it?
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
