Grounding Kit For V36 (rhd)
40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
Hello, My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered. Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
What is the SMJ connector?
