I'll put it like this: The factory airbox works fine. But if you put a stillen CAI on there, nobody would question you decision. Just because the stock ground works, it doesn't mean there aren't better options out there.
Not sure I agree with that comparison. Your greatest impediment in the intake path is the filter, not the pipework. With your cables being additional pipework, poking more points of air entry into your intake by means of more pipes won't do a thing if you still have that impediment in the path.
With your grounding, unless you have corrosion/rust at any of your existing ground points (akin to a resistive air filter), those electrons aren't going to flow any differently when the minimum requirements are met. This is much like the debate about Monster Cable vs regular/more affordable oxygen free copper cable. They both push along electrons. The question is, does one do it so much better over the other? Will that extra 0.01V in a nominal 13.8V system really make that solenoid actuate that much better? My professional opinion, no.
Therefore, we'll have to agree to disagree on this one. If, like Monster Cable users out there, you perceive a difference, then by all means enjoy. For anyone else thinking about it, take all the information on board and if you're still keen to experiment with it in the name of science, go for it. Be your own judge.
My point is that if all OEM stuff was perfect, there would be no need for aftermarket parts at all.
No argument there. I just don't believe it applies to all components, particularly the minor ones, unless you're talking about a bloody Ford. :P
Yeah.. worth a try, even if it is just curiosity.. if you can make up your own cables, it will be much cheaper!. see if you can get hold of the install instructions for the real kit. If you just connect them to random spots, you can cause problems!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
