I'll put it like this: The factory airbox works fine. But if you put a stillen CAI on there, nobody would question you decision. Just because the stock ground works, it doesn't mean there aren't better options out there.
Not sure I agree with that comparison. Your greatest impediment in the intake path is the filter, not the pipework. With your cables being additional pipework, poking more points of air entry into your intake by means of more pipes won't do a thing if you still have that impediment in the path.
With your grounding, unless you have corrosion/rust at any of your existing ground points (akin to a resistive air filter), those electrons aren't going to flow any differently when the minimum requirements are met. This is much like the debate about Monster Cable vs regular/more affordable oxygen free copper cable. They both push along electrons. The question is, does one do it so much better over the other? Will that extra 0.01V in a nominal 13.8V system really make that solenoid actuate that much better? My professional opinion, no.
Therefore, we'll have to agree to disagree on this one. If, like Monster Cable users out there, you perceive a difference, then by all means enjoy. For anyone else thinking about it, take all the information on board and if you're still keen to experiment with it in the name of science, go for it. Be your own judge.
My point is that if all OEM stuff was perfect, there would be no need for aftermarket parts at all.
No argument there. I just don't believe it applies to all components, particularly the minor ones, unless you're talking about a bloody Ford. :P
Yeah.. worth a try, even if it is just curiosity.. if you can make up your own cables, it will be much cheaper!. see if you can get hold of the install instructions for the real kit. If you just connect them to random spots, you can cause problems!
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
