Garage sale. pickup location 2087 sydney forestville or Ryde (working horus). most items can be shipped, buyers expense.
lets start with the good stuff.
R34 gtt neo highflowed turbo (14psi adjustable actuator) - $600 not nego
I pulled 257rwkw and 660nm with supporting mods on 18psi BP98 dyno sheet provided.good pull, good condition, good response, minimal shaft play if any.
R34 gtt neo stock turbo - $200
No shaft play good condition.
GFB Responce dual port BOV - $200 not nego
good condition can be set to atmospheric or plumb back Used for approx 1 month
Nistuned r34 gtt neo ecu- $400
has a existing tune 257rwkw can be overwritten.
Greddy profec spec 2 - $200
works perfectly. comes with solenoid-cables
autobahn88 Rb25det metal intake - $100
fits with pod no silicon included.
Genuine r34 skyline floor mats 5 - $150
r34 gtt neo stock airbox with snorkle - $100
r34 gtt neo AFM - $50
Cometic upper intake gasket - $30
R34 gtt neo engine cover - $50
r34 gtt stock intake pipe metal breather pipes - $30
Pair of federal 595 tyres 265/35zr18 - $100
prob 50% thread left?
post-133245-0-29543200-1427600908_thumb.jpgpost-133245-0-71822500-1427600949_thumb.jpgpost-133245-0-29058200-1427601033_thumb.jpgpost-133245-0-96701000-1427601129_thumb.jpgpost-133245-0-80628300-1427601174_thumb.jpgpost-133245-0-84517200-1427601273_thumb.jpg
post-133245-0-70503300-1427601303_thumb.jpgpost-133245-0-07311300-1427601381_thumb.jpgpost-133245-0-20395200-1427601547_thumb.jpgpost-133245-0-32071400-1427601672_thumb.jpg
Edited by mike_nazz
Im the 2nd owner i put about 7000km on it. not sure how many km he put on it.no issues. Prev owner said he got it highflowed by turbologic by someone called fred. He also said its got garrett internals.
No receipts
Edited by mike_nazz
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
