Hi Guys Im running a Rb25 with op6 highflow set on 20psi tuned by insight motorsport
The car picks up knock readings of 80+ on my pfc this is my second engine and i don't quite want to do an engine swap any time soon and before it gets asked i did get this motor retuned after the engine swap could it be bad fuel? or anything else?
I now run half a bottle of octane booster per tank to keep it from knocking at the moment?
I havent checked cam timing ill pop the cover off today and see if it has jumped any teeth.
thanks any help is appreciated
Michael
The Power FC's (especially the older ones) tend to pick up 'false' knock.
As an example I had an old power FC on my car when I had the gt2835KAI (think it wasa v2.20) which I replaced with a brand new one. Same tune on both, with the old one I used to see 20+ knock on startup and randomly get spikes of knock at really random times. With the new one, only ever got about 6 knock on startup and never really had any knock issues
Im not suggesting that its nothing to worry about and your Power FC is lying to you, but its worth mentioning
The tuner needs to put a standalone knock sensor on it and have a proper listen for knock. Log the point where it knocks if you can or at least remember where it is then get the tuner to go for a drive with you and listen for actual knock. There may be no problem at all, or it may need a retune
This is the only way to prove it for sure
  • Like 1
What Cal said is perfect, if you follow that and you are still getting knock but no signs of it through the tune then there is the chance that it could be a false reading. Having said that you might want to lower your tune to a safer limit while you work out what the issue is as you could be damaging your motor.
  • Like 1
New nissan knock sensors are ridiculously expensive. Is there any new alternative that doesn't require too much dicking around? Most knock kits use the Bosch or GM donut sensors, could these be incorporated into the ECU?
Its pretty random I have had high knock levels pop up just putting around 2000-4500 barely hitting boost then i get them at WOT but with octane booster i see nothing over 30. makes me think there is carbon buildup in the cylinder ;)
which RPM are you picking up this knock at?
its pretty random but if i had to pick it would be up top 6000+ WOT
im interested to know i would love to update them
could just be mechanical noise you're picking up, usually from my personal experience most knock occurs where peak torque is reached, unless timing up top is pretty strong and there could be a chance it's knocking there too.
  • Like 1
I've never seen an Rb jump a cam belt.
Any odd cam timing I've come across can always be traced back to a poor/incorrect belt install.
You've got a hand commander, pull a few degrees timing out of it and note the results.
Go Setting, Ign/Inj and either add fuel or pull timing. (I'd pull timing)
As soon as you turn the engine off those temporary changes are gone and she's back exactly where it was. A very conventient function for test/tune.
A lot easier than farting about with octane booster, plus you can give some accurate feedback to your tuner.
Paul's big PFc story is a mine of useful information, have a read of the hand commander section.
How's the tuner going to do a tight tune with some unknown ratio of octane booster still in your tank.
I would be checking AFRs too but johnnilcte pretty much summed it up.
Is that a statement or a question?
If you are running octane booster and the knock goes away, then you can confirm its real knock. If you want to play around with the tune, then follow Jiffo's advice. If you dont want play around, then just take it back to the tuner to fix.
  • Like 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
