Personally I would want a very good demonstrable reason to remove the quench pads from an RB26 head particularly one on a higher capacity block . My reason being the greater the engines capacity becomes the less the issue with chamber volume becomes . It gives you freedoms with piston crown designs because you don't need substantial raised sections on the piston crown to get the static CR up to a reasonable figure . Great lumps of aluminium have often been put on pistons because the CR took priority over extreme power potential . In an ideal world I'd like RB25 Neo sized chambers on a 26 head and more ideal piston crown design than R33 RB25s and all 26s have .
Sad fact of life is that the RB26 design is an escapee of the late 1980s and its showing its age .
This doesn't sound right... piston acceleration goes up with stroker engines as will squish velocity. More reason to spend time modifying (removing material) squish pads.
  • Like 2
I suspect that when the power levels start to get really high, the need/want to reduce compression so as to enable more boost starts to win out over the real benefits supplied by decent squish design, and the pads just get thrown away. Engine still makes bulk power, courtesy of monster boost.
This, removing the pads was an easy way to lower compression so they could run more boost, technology and E85 changes that
  • Like 1
My 26/30 has both pads untouched, I ran over the chambers with steel gause to remove any sharp edges and once milled to get desired chamber capacity i ran around the head with a small fine file to round off any sharp edges
I also use stock valves, if i had oversizd the valves i would have deshrouded them only
We have run 28psi from the GT-RSs and made 458kw at all 4, at 30psi it blow out the spark from to much backpressure
I wonder how much the rods stretches with more then 250psi pushing down on the piston on the compression stroke plus ignition before TDC
I spoke to the guy the guy that builds the Tilton Evo's engine the other day about this topic. He has seen one of the Gibson heads and they took both sides out. He also said that the way E85 burns changes alot of things and he recommended to leave both in. He has seen quite a few heads where the intake pad was chewed out/pitted from det. Maybe thats where the whole taking out the intake comes from?
Interesting to say the least.
I was under the impression that's the main reason the intake gets taken out.
  • 2 years later...
I personally think if you had money to burn go all out on a 25 Neo Turbo head casting . Smallest chambers and better piston crown design .
Granted a bit harder to get 26 spec inlet manifolds on but at least the variable inlet cam timing is free .
Correct me if I'm wrong but I don't think the RB 26 head castings changed much if at all from R32 in 1989 till the last of the R34s in what 2001 ? The piston crown design is quite basic - big decked plateau across the middle to get a barely acceptable static CR . 8.5 is really low by todays standards and a bit pathetic IMO with ethanol fuels . I seem to remember the GMS engines being more like 9.6:1 particularly with restrictors and later less boost . They were not slow by any means . I think the formula is smaller capacity chambers with a flatter piston crown design .
I reckon if Nissan had the money to develop the 26 right through the 90s it would have ended up more like a slightly stroked Neo 25T with the 26s externals and maybe bucket over shim valve train .
^ Agreed with discopotato. Am an advocate for going 25 head as well.
I don't think there's really much point in taking out the squish pads, you would only start thinking about that in 800+hp drag cars and none of us are doing that... A lot of us are running E85 nowadays also so squish pads can stay in for that too.
Do some research on burn patterns in hemispherical chamber designs. In particular, spark plugs.  Once you get your head around that, come back and share your thoughts.
Head and porting is still a closely guarded topic, not secret by any means, but closely guarded. Ive seen very lightly modified heads, done so in strange areas, make huge amounts of power. Upwards of 2khp, but the principles remain the same, or at the very least, very similar between most engines.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
