Consolidated everything - mudflaps added. Will be adding other bits as I come across them.
GTT Nistune package $450 – everything you need to get the most out of your bolt on mods. Never got around to installing this in my car, but all parts were purchased in working order.
R34GTT Manual ECU
Type 4 Nistune board and cable
Turbotech manual boost tee
Blitz 52mm mechanical boost gauge and cup
https://www.dropbox.....48.21.jpg?dl=0
R34 plastic eyelids $60 – in sonic silver. Slight bend in one as per picture, does not affect ‘performance’. Affix with double sided tape.
https://www.dropbox.....22.57.jpg?dl=0
R34 coupe front and rear standard bumper $90 for both – in sonic silver. Front bar is off a GT so no SMIC vent. Both in good condition with a few scratches from being in storage
https://www.dropbox.....21.30.jpg?dl=0
R34 GTT stock wheels $150 – gutter rash on most of the wheels. Some rubber ok, some not.
https://www.dropbox.....35.29.jpg?dl=0
https://www.dropbox.....33.20.jpg?dl=0
https://www.dropbox.....34.30.jpg?dl=0
https://www.dropbox.....35.23.jpg?dl=0
R34 GTT stock coilovers $50 – cracked dust boots, came out of car with <100thousand k’s and were working fine
R34 GTT stock front indicators and side repeaters $50
https://www.dropbox.....23.28.jpg?dl=0
R34GTT Stock airbox and snorkel - $80
R34GTT AFM (pink label) in working order - $70
R34 Coupe full set of Nissan moulded mud flaps in Sonic silver - $100 (pics to come)
R34GTT Manual ECU $100
Type 4 Nistune board and cable $280
https://www.dropbox.com/s/zltyv6tx49ptvz6/2015-03-30%2020.48.21.jpg?dl=0
Turbotech manual boost tee $15
Blitz 52mm mechanical boost gauge and cup $40
R34 GTT stock wheels $150 – pics of the worst of the rash. Some rubber ok, some not.
Edited by sonnyQ
Bump, prices amended.
Type 4 Nistune board and cable $260
Blitz 52mm mechanical boost gauge and cup $30
R34 plastic eyelids $50 – in sonic silver. Slight bend in one as per picture, does not affect ‘performance’. Affix with double sided tape.
R34 Coupe full set of Nissan moulded mud flaps in Sonic silver - $90
R34GTT Manual ECU sold pending payment
Everything else available, will be throwing them up on ebay
https://www.dropbox.....24.24.jpg?dl=0
R34 Coupe full set of Nissan moulded mud flaps in Sonic silver - $80
TTT
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
