Hi guys first post!
I just bought a v35 and I'd like to put on an exhaust. I've looked at these two systems from Australian suppliers which seem very reasonably priced but I can only find audio of the ultrex one. It sounded great however. Has anyone got any experience with either or a recommendation?
What would an exhaust shop charge on average to install it?
Thanks for your time, I can't wait!
I haven't heard either, but you have to be VERY careful with exhausts - there is a fair bit of pot luck/combo variance involved - reason being there are so many variables. When you listen to sound clips they don't always disclose exactly what their setup is.
FYI, each of these individually can considerably change the note and pitch of your exhaust:
- stock vs aftermarket headers
- stock vs aftermarket high flow cats vs straight pipes
- stock vs aftermarket Y-pipe (including variations in Y-pipe design and where the Y joins)
- stock midpipe vs deleted midpipe
- stock vs aftermarket rear muffler
What you want to avoid is drone, and raspiness. Therein lies the beauty of the V35 - getting the right balance between note, volume, drone and rasp.
Just go for whichever exhaust seems to be of the best construction (go for full stainless if possible), and play with it from there. I pretty much guarantee you that you will not get it right the first time, but you can add in and delete different pieces along the way.
I have a combo that I am currently happy with:
- stock headers
- Kinetix high flow cats
- customised Megan racing y-pipe
- deleted mid pipe (3" straight through instead)
- stock rear muffler
You need to muck around and figure out the combo you like best - it is quite an individual thing. To give you an idea, I have had: various Y-pipes, dabbled with straight pipe/cats delete (= too raspy for my liking), aftermarket Chinese rear muffler with Titanium look tips (very low internal quality - I blew the guts out of it in one track day, after which it was VERY loud), I had an Apexi exhaust control valve at one point, 3 different mid-pipe resonator setups.
Custom stainless is by far the best, that way you can decide how loud you want it and tuck it up much closer to the body. Fitting is also included in the price.
Never heard of either of those brands, but most kits come in from China with low quality components to keep the costs down. Hardly anyone makes decent quality exhausts in Australia anymore.
If someone needs them I have a set of V36 headers here, they shit all over the V35 exhaust manifolds...
3.7L headers, they are true 3 into 1 tube design, not log like the 3.5L. They won't just bolt to the 3.5 cat though, you would need the 3.7 cats to bolt them on, or custom decats/highflow cats.
I was hoping to make a jig for the 3.7 cats and make decat/highflow kits to convert over, but I just haven't had the time.
Ah right....thought the VQ35HR and VQ37VHR headers are around the same. Was told the 35HR OEM headers are pretty much equal length and no point of changing them out... 35DE on the other hand does not have equal length from factory so changing it may give some gain.
You could be right, I have only checked out the DE closely. The HR likely has the better headers to help with flow at the top end.
are they stock oem 3.7L headers?
Yes, surprisingly good design for an OEM header.
Would anyone be interested in a group buy from Kinetix in the states? I'm in QLD.
I want to order some cats and a plenum
If you're in QLD, there's a muffler shop in Brendale that does really good custom work. A couple of QLD members have used them. it's either Mac's Mufflers or Fat Pipes. Can't remember for the life of me right now. Full custom set up, just the way you want it. Pricier but you pay for quality and perfection.
  • 1 month later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
