So ive noticecd some mention of fire extinguishers in the car in one of the posts?
Is this compulsory? or are you talking that IF you have a fire extinguisher, it has to be securely fastened?
thanks
thanks
Compulsory
Will not pass scrutineering without one
So this is just a Skylines Australis requirement? I was at a wakefiled speed off the streets track day recently with no requirement for an extinguisher?
Where do i get one from (cheap and within 3 weeks)?
Thanks
Thanks
Most days with timing require fire extinguishers and is a requirement from our insurance
In my opinion it's piece of mind having one, could be what's stops your car burning to the ground
Supercheap auto, autobarn etc stock them on the shelf, usually only $20ish
Just make sure it's the type with metal strap and bracket and 1kg minimum
  • Like 1
ok, thanks for your help. Nice to hear they dont cost too much
I got mine from the local Big W. It's the bracket you should be more worried about (unless you're handy with metal).
I got one of those 'evok3d' ones, bolt in, works great.
I promice asking the boss tomorrow about if im able to have day off, tax has cleared so entry can be paid, and maybe some coil overs and tires for the 32 ;)
  • Like 1
Yeah ive had a bit of a look and actually the cheapest ones seem to be at Bunnings and the one ive gone for is from Officeworks! Didnt check Big W but too late now.
See you guys in a few weeks :cheers:
Just to be clear, your car WILL be scruitinered.
That means, someone will look over it for leaks, loose items in the cabin/boot, sufficient tyre tread, brake operation, battery secured (big one! With metal, not zipties!), seat belt condition and operation.
If you are unsure about any of these things, please ask, and/or get it sorted before turning up on the day :)
  • Like 1
Paid in full. Sorry for late pay but have confirmed i am free that day.
On another note will my car fail for having rat crap in it, apparently parking your race car on a property is not the best storage :glare:
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
