Houston we have a problem ! ! !
After months of anticipation and a shit load of car preparation in the last couple of weeks (full fluid change, discs machined, new pads, seat and harness mounts improved and lots of little issues fixed including mounting a set of Pirelli wets on new rims just for the rain that is forecast) we were doing one of our system check runs yesterday to discover we now have a bearing failure.
Unlike most Skylines with bearing problems ours is in the turbo and it is making a hell of a racket as soon as it tries to come on boost.
In addition to the entry fee we have invested money in accommodation and van hire for the day (for all of our stuff) so we will still attend but will be in a hairdressers car (e.g. 4 cylinder daily). We will still have some semi's and wets to run on the car so if it is wet we still may be able to keep up with traffic in our respective groups.
See you on Monday.
Hey All,
Any suggestions on tyre pressures for a wet rainy coldish day?? Should it just be left normal or would you guys consider a change for this type of weather??
Im pretty sure my pathetically slim and cheap tyres are gonna struggle, need all the help i can get :0
Thanks
  • Like 1
Hey All,
Thanks
I was thinking the same thing!
Hey All,
Thanks
Leave them at normal pressure you would run on street then adjust as you go
Normally in the formula fords we run them a little higher, you think of it as an ice skate, you want a nice edge to cut through standing water ect. If only damp you normally run them on a preassure you are aiming to get to when fully warmed up in the dry.
So if in the dry you want your tire temps at 25psi and normaly to get that you would start at 23psi, you would just start them at 25psi and check when car returns from session and bleed until you hit that 25psi.
Also my daily will be used. My 200kw R33 so hoping to crack a 10 if not to went considering my underpowered R32 gets mid 15's
ECU never turned up. See you all there
Hey All,
Thanks
Not sure what sort of tyres you have, but I'd put at least 40psi cold in there. You can always let air out.
Hey Mate,
This sounds like the way to go, especially considering Calsonic14u's comments.
fyi, ive got Gemstone 215's all round, on17's. I know what you're thinking....wtf, wat a noob. But they came with the car and like 95% tread so i thought id rpi them up quick then upgrade. Never anticipated the rain though :no:
Lol DW im running a second hand set of Pirelli on the rear and Re001 on the front on 17s atm on my daily, needless to say i wsnt planing on running her tomorrow lol.
my tires are set atm at 36psi all round, probably wont be bleeding at all haha. dont even think im taking tools :P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
