Looking To Sell...
R32Abuser
 Share
Its been a while since I was last on here...not a lot has changed haha
The time has come where I cannot justify (economically) running my skyline.
$1000 a year in rego and a tad less in insurance (full comp) burns a hole in my pocket when realistically I do not drive it often enough to enjoy it. This is not a decision which I have taken lightly (it was my first car back in 2004) and I will in no way get back the money I have put into it (probably $20,000 over the 11 years of ownership).
Anyway - I'm after some advice of what I should be asking. Rough specs/mods as follows:
1993 R32 GTST M-Spec
Owned since 2004 @ 128,000km....Current km ~175,000km
ENGINE
RB25/30DET (R32 RB25DE head, RB30E series 2 block)
CP 9:1 Forged Pistons
Spool 4340 H Beam Rods
ARP rod fasteners
ACL Race Series main bearings
ACL Race Series big end bearings
ARP head bolts
Cometic MLS head gasket
refer to - http://www.spoolimports.com/spool-engine-rebuild-kits/nissan/rb30det-rebuild-kit/holden-nissan-rb30det-dohc-rebuild-kit-with-cp-forged-pistons-9-0-1
This motor probably only has about 7000km on it from when it was built in 2011.
Garrett GT3076R 0.82 A/R Turbo
3 inch metal intake pipe to turbo
Trust VSPL FMIC
Blitz DSBC Dual Stage boost controller (Low boost ~15 PSI, High Boost ~19-20 PSI)
Q45 AFM
Bosch 550cc Injectors
NisTune R32 RB20DET computer with map to suit above setup on BP98
Bosch 040 fuel pump
Nismo adjustable fuel regulator
3" Turbo back exhaust (Bell mouth style dump to suit GT30 to Catalytic converter to resonator, to JUNBL rear muffler)
I have a 3" "big" magna flow middle muffler that I was intending to fit which I would throw in to replace the resonator
Power - makes 281 RWKW on Jaustech's dyno (can attach dyno plot)...240 of those RWKW available from about 4000RPM. Could crack the 300 RWKW with bigger injectors and a Z32AFM.
DRIVELINE
RB25GTST G/box (std internals)
Nismo engine mounts
Nismo gearbox mounts
Jim Berry "race" clutch (reasonably light on the foot, but does bite hard)
OEM flywheel
Modified RB20 GTST tail shaft (w/ RB25 yoke) to suit gearbox and diff
STD OEM V-LSD diff (I have an R34 RB25 Neo torsen differential at home which is easy to fit up...just needs backlash to be setup)
STD OEM driveline otherwise (more than adequate for the power output)
SUSPENSION
Full Sydneykid Bilstein/Whiteline setup (http://www.sau.com.au/forums/topic/85591-r32-gtst-whiteline-bilstein-suspension/):
Bilstein B4 "c" clip height adjustable shocks valved to suit suspension setup
Whiteline "lowered" (25mm lower than stock) springs
Whiteline front and rear fixed anti roll bars
Whiteline front upper camber arms (adjustable)
Whiteline front adjustable castor bushes
Whiteline rear camber arms (outer IIRC)
Volk Racing GT-P's (old school) 8" fronts, 9" rears IIRC (they came with the car back in 2004)
Bridgeston Adrenaline RE001 235/45/17 fronts and rears IIRC
Not fitted but will chuck in -
Whiteline HICAS elimination kit
Whiteline subframe replacement bushes (NOT PINEAPPLES)
Superpro diff bushes
Superpro steering rack bushes
few other odds and ends which I have accumulated over the years
BODY
Genuine R32GTR front bar (will throw in the OEM mesh that goes over the intercooler)
R32 GTR rear wing
R32 GTR rear boot
Will throw in: GTR style fibreglass side skirts (in primer)
R32 GTST boot/wing
Issues - one of the rear quarters has a sizeable dent in it about the size of a football and about as deep as a book (thickness). I have been quoted about $600 to fix it and paint. The boot also has a small dent in it also. IIRC I was quoted about $1000 (maybe a touch more) to fit the side skirts, fix the dents and paint. Will post photos when I get a chance.
MISC
R32 GTR centre console tripple gauges (not connected)
Alpine head unit
GReddy turbo time (not connected)
Viper (unknown model) immobiliser
Not fitted but will throw in:
Focal 6.5" front splitters (cost me $500 at the time and never fitted)
Alpine 4 channel amp
wiring kit to suit the above
Viper immobiliser (remote start capable, few other features)
There's probably a few other things I've missed out but that will do for now...
I will post pictures when I get a chance!
TL;DR - give me a rough price that I should sell the above for.
Cheers!
Edited by R32Abuser
  • 1 year later...
  • 4 weeks later...
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
