My R34 GTT project goals have changed, from fast / responsive street car to dedicated track car. As a result I'm now selling the new complete turbo kit I had originally bought for it. It includes:
Garrett GTX3071R turbo
Genuine Garrett 5 bolt 0.82 a/r rear housing, IWG
Garrett 14psi wastegate actuator
Spacer plate to fit to OEM exhaust manifold
Turbo nuts and studs
All water and oil lines (braided)
All other required fittings - banjo bolts, crush washers etc.
All required gaskets
Compressor outlet silicon elbow
Dump pipe to suit turbo, ceramic coated
It comes with EVERYTHING needed to bolt straight up to an RB25. I bought the whole kit through Kudos Motorsports, and they obviously sourced it through GCG Turbos in Australia. I had test fitted the turbo to the exhaust manifold, but nothing has been run and the turbo is still as new.
Fellow forum member Mick_o made a responsive 335rwkw from memory (on E85) with the same turbo in his R33.
The whole kit cost me about $3k, and then I spent extra changing the oil and water lines to braided items and getting the dump pipe ceramic coated. I'm looking to get $2,100 for the whole kit, plus delivery.
Cheers
Justin
  • 8 months later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
