Educated Guess At The Final Tune Results
You do you. But I always resist changing things that don't matter, in favour of spending and doing on the things that do matter.
By drifter17a · Posted
Cover is damaged per picture I uploaded so want to change it. Do you reckon balancer could be f**ked and need changing? -
No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
Disconnecting rods! must have been an unpleasant surprise...
So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
