The setup you have if perfect ( except the exhaust, should be 3.5" min tip to tail ), it is just set up and tuned way off the mark
It is 3.5" exhaust, but it is on a 3" cat I think and stepped up to take the 3.5" exhaust
So I guess I need a bigger cat or ?
The dump and cat are the most important part of the exhaust as that is the first port of call for the exhaust gases
Should be 3.5 from the turbo right through
See if you can get that fixed before heading back to CRD
Venom 5" bodied 3.5" cat is best for flow
  • Like 1
Thanks for the info mate ,Paul was saying the 3" cat would cause a problem with the flow.
Here is a pic of the other side of the cat
That cat is really doing you no favours, changing that alone should give you a good gain, this is under the assumption the catylitic convertor is still intact
3.2ltr is alot of motor to flow through a 3" and while it will flow 400rwkw 3.5" will do it easier and with less backpressure, exhaust backpressure hurts turbo performance
he was talking about the back pressure and said I should have a 3.5" exhaust , I told him he had me put a 3.5" long before the build, then said maybe a 4" would be better?
I do not think they take any notice what they are doing or what they have done at times , I guess when you work on heaps of cars you forget, not hard to have a quick look to see what is holding up the flow and offer an alternative.what if the cat is not intact . If it is not , would it make any difference to change it ?
I will ask about the Venom and do something about it before I take it to Sydney if it is going to help..
I honestly think you need 4inch for the first half, and a 4 inch cat if its "high flow"..
If your keeping it legal then yea a 5" is the way to go
To put it in perspective, Paul has twin 3 inch exhausts on a 2.8
Once again CRD should know better
Trying to keep it legal, well as I can, I do not know where I want to stop with the mods :/
Why would 5" be better, do you mean run a complete exhaust system, just spent $2500 on the one I have, haha
4" system with 5" cat.
In the photo it looks like they necked the exhaust to accomodate the small cat.
So in anticipation of the build they tell you to fork out 2600 beer tokens for a 3.5" exhaust and now they tell you a 4" might be better? Alternatively, they built an engine package and tuned it all at your considerable cost, and immediately after tell you the exhaust is too small? Maybe I missed something.
3.5" will be fine for your goal, though a 4" would be better
I have twin 3" into single 4" on my 3.0
Like i said i would change from the turbo to the stepup in 3.5" with a 5" bodied 3.5" cat and be done with it and that will help the turbo response by allowing the gas to get out of the turbo easier
No Mate , the exhaust was done before I made my mind up to do the build.
But as you can see they did step the exhaust down to fit the cat?
I am not sure if the cat has its internals ??
If I do something with the exhaust I will make sure it is done properly. I will get as much info as I can before anything is done.
Where do you stop? Exhaust has nothing to do with an engine build. It has everything to do with performance, but if it's not on the list of things to do where does one stop?
Can't expect them to do all the recommendations. Engine build isn't a car build.
I thought I was finished with it, haha
Thought the exhaust was OK, I did not just do the motor, did a job on the drive train, C Spec coppermix twin clutch , Quaif front diff, modified the trannie and have a Nismo 2-way LSD on the back and that all works a treat , add the AD08Rs and all good :)
Well CRD is a pertormance shop and should know enough to know to atleast recommend enlarging the 3" section to 3.5" while car was getting upgraded
I think this was another problem, there was no guidance as to what the car needs, to make the bolt ons I chose work better, maybe I would have said NO, but at least put it out there ??
I will ask them what I should do with the exhaust, then I guess I will have to try and sell the old new one :(
Everything seems easier in 20/20 :)
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
