Does anyone have a 4" system that is legal ??
Does anyone have a 3.5" that is legal ??
If so, what is it ?
put a Ferrari badge on your car.
They have ridiculously loud exhausts and never seem to be defected.
  • Like 1
Pete
Date for return of car to builder?
Hi Mark, going back first week in June, they will have it until it is all fixed, hopefully :/
I hope I do not get stuffed around anymore, that will really piss me off :rant:
The badge is worth more than my car :/
Maybe one will fall off and I can find it :whistling:
haha, that hurts :(
Probably more $s spent
Well for the same year model, BUT mechanically mine is virtually new from the radiator to the tail pipe.
I would not swap mine for a 400HP 1999 360 Ferrari :no: Also nowhere to put the kids :)
  • Like 1
Here's my exhaust pete, it is 3 1/2inch and ive been stopped a few times by popo and no issues at all, even my old man is ok in the passenger seat , that means something lol, stainless steel jap system with cat replaced with 100cell and rear muffler is X force, cost $800... without the rear muffler it was terrible, but with the big ass muffler on the back its fine, add another fat muffler in the middle and you'll wonder if the engines even running or not.. :whistling:
Edited by AngryRB
Sounds good Mark, well if I could hear it :whistling:
Just some quotes regarding my fuel situation , if I am going to try and get it all working properly I decided I would rather have over kill than run it on the edge.
Been thinking of getting an Aftermarket Industry surge tank with twin walbro 460lph pump mounted in the surge.
It seems the single walbro 460lph pump should flow around 450kw by itself. The issue is the plastic fitting in the fuel hat.(fuel gets pumped from the pump up through the fuel hat to the outside of the fuel tank via the "hat" then through the stock fuel lines to the engine bay.
On the R34 this hat is a bottle neck as the inside diameter of the fitting is around 3.5mm.
Just need to spend some more money :)
https://youtu.be/zY13FltTn18 is on dyno, and https://youtu.be/2ZjV5Pb5ySc is on a quiet road, full 3 1/2 inch system off GT3076 and external plumb back, only one large muffler at rear... ( excuse the crappy footage and Tein coilover old couch sounds lol)
Edited by AngryRB
Thanks, I will fire up my PC later and have a proper look at both posts, this laptop is crap :(
Has the car still got the limiter ,180kph set up or over ridden. I had this on the 350GT and as a DD had no trouble with it
Fuel hat can be changed to alloy with a decent fitting in it.
Got a photo of mine.
Using genie turbo mufflers.
Turbo muffler, are they more restrictive than a chamber model.
I see you can also get them with insulation to quieten them down if you want.
The Genie, could not find out much except they put them on bigger 4WD types
Do you have to get these made or is it an off the shelf fitting ?
Your builder supplied mine. Along with the AI install
Edit. Something like this, but not this one
http://www.powerhouseracing.com/p-4597-phr-fuel-hat-for-nissan-240sx-s14-skyline-r33-r34.aspx
  • Like 1
I think I need a break from going to Sydney after this and will wait and see if they fix the stuff ups properly .
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
