Good luck.
After I had my engine built (8000km's after) I had a "o" ring fail on the oil cooler and it start to leak oil everywhere. Guys had me in the shop the day after i found out and fixed the same day.
They seemed to care about their build work and the engine. Was reassuring to say the least.
They are a very busy shop. GTR's everywhere.
Good luck.
Half your luck ?
That hurts Mark :)
They do some really good builds and the blokes there know what they are doing.
Maybe my type of build is not what they specialize in as they seem to get into the drag/speed cars.
Anyway, hopefully after I drop it off on Monday I will get it back firing on all 6 in a week :)
It really does not like starting in the cold weather :(
Sounds like they didn't go into the cold start setup on the ECU and compensation settings. Hopefully it all goes well when it returns.
Their other tunes were fine.
I think this is getting worse because it is running rich, the plugs would be like they are covered in black velvet and I do not feel like having a new set of plugs put in, just did that, already put 3 sets in, well I didn't , my mechanic did :) +$
Looks like some good work on the 3.2 stroker here from CRD
https://youtu.be/_cT-8PEwGuY
sounds awesome...
Not a street gtr at all, as suggested. Actually not even a gtr with an auto in it. What a load of crap . It's a drag car.
The 26 stroker sounded much better then the vl block.
So if an Auto is not counted , what about the sequential box ?
Even my heap cannot be called a real Skyline, different motor,turbo,ECU,radiator,clutch, Tranny, front and back diffs and a lot more ????
So if it is not counted with an Auto box, when is a skyline, not a skyline ?
There are two GTRs in NZ that have done 7 second runs but they were drag specials. Rips has built a few "street" (as in road registered ) R34 GTRs for dragging with powerglide boxes doing 8s but the fastest proper street GTRs that I know are doing 9s. There are a load of Street GTRs doing 10s.
Exactly the same as a tubbed 120y with a Sb chev , 2 speed power glide and 9 inch doing 9s. No difference
So as long as the outside resembles your model Skyline, it is ?
Whatever, I like it :)
So do I,
but it's a drag car not a street car.
Before I bought my car it was being work by them, but not for a street car, laggy as fark. It was an impulse buy and turned into a financial nightmare because I am a stubborn SOB, haha
But I really got to like the car and here I am, still going at it :wub:
