Educated Guess At The Final Tune Results
I never had the fuel under 1/3rd , they told me not to go below 1/4 until I get a surge tank if I am going to push t a little,
I suggest to get this sorted before you take it again, not nice play Russian roulette with a new motor.......
  • Like 2
It's not the valve springs is it.. Those cam lobes are very aggressive
Same springs and retainers as what's in mine. There shouldn't be an issue unless there was a mega mess up installing.
Having said that, if it's coughing in neutral, it won't be springs as there is no boost.
t will all be done and I will be very careful until it's done.I never really push it under half full and my pushing is not like you blokes drive :)
Things are looking up, my builder called me and we were talking about the car and he has put in a starter motor for free and going to run a 3.5" Dump and Cat for me "no Charge" so it will be 3.5" all the way. That was a great offer :banana:
Just a matter of finding out where the water is going , a re tune and off we go :)
  • Like 4
Good work Pete, when do they think you'll have it back with a new and improved tune?
Hi James, not sure mate, but I would think he will do it ASAP, might get rid of a bit of back pressure and and flow better ?
Depends on the DBs if I will look at a quieter muffler that still flows but I will wait and see how it sounds and go from there as this exhaust was pretty quiet, well quieter before the build :/
NO, I free revved it and sitting on 5500rpm it started farting.
They have to work it out, all they have to do is drive it , they will fix it, no problem :)
I just wonder if they tweaked it yesterday on the dyno, it never went over 7000rpm without sounding like you hit the limiter but it is set at 8500rpm
doesn't have a neutral Rev limiter does it?
Factory ecus do it, should be possible to program it.
No mate, I am running a new Haltech Platinum Pro 34GTR and the limiter is set at 8500rpm.
I think it has a limit of 4 or 5000rpm until the motor is running at a normal driving temp around 70 degrees. I never drove the car hard until it was hot.
Got me stuffed, ran to 8000rpm + on the Dyno when being tuned and when I just took it into Sydney on Monday :/
But it will be fixed soon and I will be a happy camper :camping:
Holy crap!!
They must be reading this thread haha
Let's hope so, so many injustices here.
Good Pete, glad they are making things right for you.... As they should. Make sure you post up vids when you get it back.
Great news, Pete!
Will they be doing the flex tune and winding it up to see what numbers this can punch out?
Not having it done yet, I am still trying to work out what I will do with the car after I get it back and see how it is going
I always said they would fix any of the problems, shit happens and after you have waited for a build to be finished and run into a few probs when you get it back it gets you frustrated, living so far away just adds to the frustration :yes:
It will be interesting to see what difference the 3.5" dump and cat make when it is being tuned ?
You'll break 400kw with it I bet.
You'll see how much difference a good dump does.
Yeah i agree i just had a good dump! Feel so much lighter! :D
Great news on the car Pete i think thats the least they coulda done being the high end customer you were! Your build wasn't exactly a budget build so why they left pieces of the puzzle out like dump pipes etc before the tuning process was beyond me?!
  • Like 3
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
