Leave the poor guy alone. I would also be very edgy after everything he has gone through with this car.
True. Sorry mate.
Sometimes a bit of friendly banter gets taken the wrong way if your not in the right frame of mind.
But the main thing is that Pete beat the Tiida .... That's the main thing even at 10000 rpm. Would have sounded awesome.
  • Like 1
Bit angry today Pete
No mate, its all good fun :)
I have never said I was any type of gun driver, I just like cars :wub: had a 911 and a TT300zx I used to push a bit, but I was a kid, 50 year old.
Everyone has their preferences , mine is a car that dives like a street car, one that has a bit of grunt from down low.
Do not need 3000 idle Ben, is that how you blokes do it. Me at 2500rpm and want to get it going in any gear drop down 1 gear and away you go, LOL
But serious it is great on the twisty stuff, so much fun. Not sure you could do the same on tight one lane roads with a T88 or something else that gives you 700 or 800 peaky HP, but I can only guess as I do not drive fast GTRs , just my heap :)
My car is the best fun you can have sitting down, well , a lap dance maybe ?
True. Sorry mate.
Keep the banter coming mate, that is what makes the Forum fun, farken love it :banana:
Have you got your car back yet Pete?
Not yet James, had an email this morning saying it looks like the leak has been fix but they will do some more tests over the next couple of days to be sure .
Not sure if they will be doing a new Dyno graph , soon see I guess ?
Things are looking up :)
  • Like 1
At 70, I hope to be a much much more bitter and twisted old man than you. Pretty sure I am now at half of 70.
Oh don't worry mate , I was very bitter and twisted at 70 but now I am 73 I have matured , guess it comes with age , LOL
Just thinking to myself.... I feel more anxiety over and your car in than my own. Ha ha. Ha. Might have to drive up from Melbourne so you can take me for a spin when you get it back.
HAHA, that's why I have chilled, I left the anX to you. I lie , I had / have enough anxiety for the both of us. It's been a long 9 months :)
And it's not over :/
Edited by Nismo 3.2ish
They are probably just putting the head back on now pete, takes more than a few days to strip a motor again, lol... :ph34r: apprentice stuffed up again..
Thanks Mark, now my head is exploding thinking about anther 5 months getting the motor re built :bomb_ie:
No problems, I will be picking it up VERY soon and looking forward to a little spirited driving to see how it is running :)
Got a date for pickup? Good RB30 blocks are getting harder to find.
They are going to do a few more tests and I should know by Friday :)
Just hope I got one of the good ones, they did all sorts of tests on my RB30 block, like below
ENGINE MACHINE WORK INCLUDING HOT TANK BLOCK, ACID
WASH , BORE AND HONE , BALANCE ENGINE COMPONENTS.
DECK BLOCK, MACHINE BLOCK FOR O/S HEAD STUDS,
MACHINE WORK FOR AWD ADAPTOR AND ENGINE BRACE KIT.
MACHINE SUMP RAIL TO TRUE UP ENGINE BLOCK.,RELIEVE ENGINE BLOCK FOR 3.2LTR STROKER ENGINE.
1.000 SONIC TEST AND XRAY ENGINE BLOCK TO TEST FOR SUITABLITY
Sounds like they did their best
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
