Have seen that before.. Leaks under hard throttle only
I came in after a few different runs and let it idle, seen nothing. Turned it off and watched for a while, nothing. Backed out of the garage, nothing on the ground, it was a hard farker to find :/
From what was said there was no noticeable power gains with the addition of the larger dump pipe, said he took the exhaust off and there was some good gain. Very disappointing at this stage but as long as it is going hard to 7500-8000rpm without farting and I do not have to top up every day, all good :yes:
Good power to 7500.
So what if it doesnt make peak hp after this.
Get it back and drive it and make sure there are no more gremlins.
Enjoy the response because that is how it was setup.
Dont worry about dyno queen figures......... just drive the f#$kin thing.
Good power to 7500.
haha, I know what you mean. This thing was still fun when it would only go to 6000rpm , all good.
I only know how I want it to feel, Dyno is a window to see how it gets to the 7500rpm :)
They said there was no noticeable gains on the dyno with the bigger dump and cat, but maybe the response has picked a little up with the extra size and not noticeable on the Dyno ?
Edited by Nismo 3.2ish
I am sure the car will be OK, it s not in there interest to give it back to me stuffed again, shit happens but that would be stupid :/
If it is stuffed I will have another mechanic look at it !
Skids. Limiter bashing. You have to check the rev limiter.
Will do mate, I have just the private road to test it on, shake the limiter, not sure about the skids, this sucker holds the road tight on all 4 :)
If they have fixed the problems and all is good, even near good is good enough, I do not want to go to Sydney anymore for work on my car, I will find someone closer for any smaller type jobs.
I will never need another build, I am done with it and this car meets all my boyish needs, love the look, its history, goes quick in a straight line. great on the twisty shit and I love driving it , farking heaven :worship:
  • Like 1
It has grip????? What is that like?
My R32 gets its drift on easy :)
Need a controller.
haha, I am the controller :)
Your 32 sounds like fun, years ago I would have been there with you.
But I like the feel of it holding the road and wondering when it will let go, thats enough excitement for me, to each his own.
Just a few hours to go before I get an idea if it is going any better, fingers X
Then just a couple of touch ups an in a few weeks, all done :)
Whoooops said that before :/
  • Like 1
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
