Educated Guess At The Final Tune Results
Have seen that before.. Leaks under hard throttle only
I came in after a few different runs and let it idle, seen nothing. Turned it off and watched for a while, nothing. Backed out of the garage, nothing on the ground, it was a hard farker to find :/
From what was said there was no noticeable power gains with the addition of the larger dump pipe, said he took the exhaust off and there was some good gain. Very disappointing at this stage but as long as it is going hard to 7500-8000rpm without farting and I do not have to top up every day, all good :yes:
Good power to 7500.
So what if it doesnt make peak hp after this.
Get it back and drive it and make sure there are no more gremlins.
Enjoy the response because that is how it was setup.
Dont worry about dyno queen figures......... just drive the f#$kin thing.
Good power to 7500.
haha, I know what you mean. This thing was still fun when it would only go to 6000rpm , all good.
I only know how I want it to feel, Dyno is a window to see how it gets to the 7500rpm :)
They said there was no noticeable gains on the dyno with the bigger dump and cat, but maybe the response has picked a little up with the extra size and not noticeable on the Dyno ?
Edited by Nismo 3.2ish
Skids. Limiter bashing. You have to check the rev limiter.
Will do mate, I have just the private road to test it on, shake the limiter, not sure about the skids, this sucker holds the road tight on all 4 :)
If they have fixed the problems and all is good, even near good is good enough, I do not want to go to Sydney anymore for work on my car, I will find someone closer for any smaller type jobs.
I will never need another build, I am done with it and this car meets all my boyish needs, love the look, its history, goes quick in a straight line. great on the twisty shit and I love driving it , farking heaven :worship:
  • Like 1
It has grip????? What is that like?
My R32 gets its drift on easy :)
Need a controller.
haha, I am the controller :)
Your 32 sounds like fun, years ago I would have been there with you.
But I like the feel of it holding the road and wondering when it will let go, thats enough excitement for me, to each his own.
Just a few hours to go before I get an idea if it is going any better, fingers X
Then just a couple of touch ups an in a few weeks, all done :)
Whoooops said that before :/
  • Like 1
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
