Educated Guess At The Final Tune Results
I would be nervous picking it up. Hope its a frickn animal been a 3.2L.
Should have given it to RIPS those boys know how to build a RB30+
The latest R32 that runs 9's is a monster.
I doubt they would of recommended a 3.2 with a 6262.
  • Like 1
If I was after big HP I would not have used the PT6262 either, just wanted one that spooled sooner for my please on the street, all good :)
I know you weren't.
Just saying its pointless to recommend one workshop over another with so many variables.
Congratulations Pete. Glad everything seems sorted. Just in regards to your above comment, big HP you mean 750+ and yes I agree there would be trade offs. But selecting a turbo for 600 HP would not have sacrificed lower end that much on a 3.2. Hardly noticeable.
I know you weren't.
I only know 1 workshop so that leaves me out of this
But like all businesses , the owners believe their product or procedure is the best otherwise there would be no variables :/
Thought you went to lunch?
Your point Sir ?
I am now at the point, were I wish I did not go to lunch as the grapes turns to poison and make one feel like shit :)
This is probably how the Whale's motor feels after a chamber full of vegetable products burnt to shit :)
thread needs more pics and vids :ph34r:
Glad your happy with it pete, that's a strong power curve...
Thought I had a little misfire at around 7000rpm this morning, do another test tomorrow morning but running strong. Did a little 5500 launch, wheels just skipped and away it went, had to grab 2nd pretty quick :)
I am going to finish it off in a few weeks. It will be getting a new flex fuel tune. It will be interesting to see how a different tuner does with this setup ??
Not much to see in pics, apart from the dump everything is the same, boring , but never got sick of looking at them :)
  • Like 2
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
