So if I go by that graph the 3.2L has 300KW at the same RPM as my 2.6 (pretty close).
How is that even possible? I guess if it had a torque graph (why?) then it would have a massive increase.
But it is stopping at 7000rpm. Please tell me I am reading it wrong.
Edited by Stixbnr32
Turbo is too small. Turbine housing too small which restricts flow and chokes the engine. In this scenario you have no choice but to cut boost.
It will be interesting to see what an e85 tune does because if it makes no significant difference then the turbo selection is the problem.
Why would boost need to be cut?
I have a .82 housing on mine and boost holds flat to 8000rpm
Edited by sky30
Yeah the graph is slightly strange isnt it.
Well as long as it feels good I guess it is ok. I still think 7000rpm is low but if the turbo cannot flow it no point revving anymore.
At least its not spluttering and leaking water.
That is a success.
I would have thought boost would have carried on the whole way through and if there were lean patches from fuel/spark they would have suggested a fix with the amount of money spent on the engine.
Have they had their top tuner leave recently or something?
The limiter is set at 8000rpm. On the first tune @ 8500rpm .
The PT6262 CEA is rated over 700HP, some blokes say they get more, why would it stop at 600HP ?
When the Turbo was put on he changed to a larger back housing , size ?
So the Turbo should be good for at least 700HP ?
Could it be the spark ?
Put it this way my turbos are rated at 650hp and I am not pushing them with the same power you have and my boost is 22psi.
What size are your injectors? They can tell straight away if it is running lean and pull boost. Only reason I can think of to pull it.
But they should tell you and then recommend a fix. No point even going near E85. Go from 24psi to 18????
The injectors are ID1300
It is definitely not as rich as it was, but still a little soot comes out on start, pretty normal but nothing like it was since the build , it was heavy.
Going to have a AF sensor installed. The Haltech R34 Pro has , Wideband “auto tuning” using user definable target AFR table. Not sure if that is the same function as a sensor ,but the next builder will know
I think the boost could have been pulled because it was still farting when the boost remained higher. Just an uneducated guess ?
The car will be checked and sorted out before or during the next tune , I am not going back to Sydney to do it. Looking for a shop closer to finalize the work I want done.
Until then I will just drive it and have some fun :)
Yeah just drive it :)
Fair enough on the travel factor. I am not sure about that tune.
But I am sure the engine is super strong and you will have a lump of torque down low.
I still have all the response in the world when my RPM is high :) hahah.
If the engine flows too much air for the turbo, it will choke, limiting achievable power and rpm levels required.
Same way as a 2.5-3" exhaust is fine for a stock motor, but not one with a bigger turbo/motor.
PJ has got the rated number and more out of a few PTE turbos, 2l, 4cylinder, 40+psi.
Anyone care to work out the equivalent flow of a 3.2l, 6 cylinder at half the boost?
That's good and fine to work it all out on compressor maps, but on a 3.2 you have a shit load more volume through the turbine. if the the rear AR is too small then you get back pressure prior to the turbine which not only slows down gas velocity but creates all sorts of issues with cylinder pressure and combustion events. That's why you have to cut boost.
In a 4 cylinder you can run big boost because you haven't got the volume of gas, so exhaust gas speed dosen't suffer and you can run a lot more boost (compessor) through the same turbo because the exhaust gas volume is a lot less, so no back pressure issues therefore high gas speed through the turbine.
In Pete's senario he wants response so who cares about top end power, its really all over by 7000rpm ish and that's where he wants it.
Good turbo for response from lower rpm, crap turbo from 5500ish rpm and up.
Edited by XGTRX
That's good and fine to work it all out on compressor maps, but on a 3.2 you have a shit load more volume through the turbine. if the the rear AR is too small then you get back pressure prior to the turbine which not only slows down gas velocity but creates all sorts of issue with cylinder pressure and combustion events. That's why you have to cut boost.
I agree, which is why I can't work out why people still want/expect it to be making 700hp
  • Like 1
have to see it through pete!!
I just got to know..
I do not know how to stop, haha
I will do the mods to finish the build off, I do not like taking a chance with the work that has been done. Do the surge tank and pod cover, plus a AF sensor if needed. The idea of making sure I have 1/2 or 1/4 tank before playing would drive me nuts.
I was thinking of trying a bloke in Port Macquarie but do not know anything about the shop.
Everything will be checked out, I have spoken to a shop in Gosford about the work and the tune. He seems to have a good reputation and I can get there and back easily, saves time and money :)
6262 is rated at 730hp, if there are no restrictions on the motor it should acheive close to that figure.
Peter, what wastegate and boost controller you got?
HKS, EVC 6 boost controller
Showed Paul some pics and he said it is looks like the old HKS wastegate ?
Whats wrong with the tune? I thought it was all sorted
Edited by XGTRX
That is alot of boost drop. Either they didn't tune in the controller properly or they are pulling boost for a reason.
Either is likely in this case I suspect.
Covering up an ignition issue, or lazy. Take your pick.
  • Like 1
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
