If its ignition problem it's only a matter of time until it eventually becomes a problem again..
Pete you can either do LS coil packs or wire in a morristech igniter if it becomes a problem
  • Like 1
Whats wrong with the tune? I thought it was all sorted
I do not think it is sorted, the way the boost is dropping off, something is wrong. I did not have a chance to do another rirve this morning
Doing some other work and then getting a new full 98/E85 Flextune but only after everything checks out .
It will all be checked out Joey, there has to be an answer to this :)
If were mine I'd be going to JEM for future work, seen enough guys on here get results, I might even take the drive from QLD, hahah, nah too far..
Haha, yeah, that's too far, they say that Jez is pretty good , lets see what he can do :)
  • Like 3
Everyone talking about this response down low - I bet he has a stack of it.
But he doesn't have any RPM to play with after that.
I am sorry it is not good enough in my book.
It was Pete's choice to have it this way. Don't be sorry because you don't like it.
Hey pete, got a vid of some 600hp GTR's , give you some motivation to get on the track and enjoy... lol...
Yeah, liked this. I have watched it before and always good for a second or third squiz :)
It does make you want to give it a run :thumbsup:
Yes it was my choice and do not regret it, maybe I was pissed off a few times, but when it is sorted it will go hard to 7500rpm but starts 2000rpm earlier, 900Nm is not too bad . So it is like someone else's car going to 9500rpm, but starting at 5500rpm. I like the idea my motor is not revving its head off.
when I first got the car it would go to 10,000rpm +, but :no: :no: Thanks.
Even with the crap I went/going through , it was worth it and it is not over yet, different tuner with a different approach may get more of what I want, if not and it runs freely to 7500 maybe 8000rpm , I will be more than satisfied and it will be more than I need,,,,,,,,,,,,,,,,,,,, but,,,,,,,,,,,,,,,,,,,,,,, I still want it, haha.
Not compared to the T78 in the 2.6 once it kicked in @ 6000rpm and then your head would fall off, so NO. I think after you have had a bigger turbo on, it ruins you a little as far as the initial boost feeling goes :/
Now it is more linear and feels very strong and starts to get going @ 3000rpm but still keeps you in the seat until you take your foot off...
I want to take it past 7000rpm. (my kids on holidays and very time consuming :) I will try to do that this morning just to see what happens, I thought it missed a little around 6500rpm but have not had a chance to confirm it yet?
Just took it to 8000rpm, went freely to 7500 and fell off to 8000, limited at 8000rpm , I was told.
So from 3000rpm to 7500 it is pretty good, so 4500rpm to play with , still wasted on me , but love it:)
It will be interesting to see what the dyno reading would have been if it could have held 24psi instead of dropping to 18.5 psi ??
I haven't yet needed/been able to to rev mine past 7000, maybe I'm driving too soft Pete!
Would be interesting, but I doubt it can flow much more air than it currently does at that rpm on a big capacity, hence why dump mod didn't change much?
I would not often take it past 6000rpm, just a test run to see what happened . Straight line diving, haha
See how it goes with the next tune
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
