Educated Guess At The Final Tune Results
If its ignition problem it's only a matter of time until it eventually becomes a problem again..
Pete you can either do LS coil packs or wire in a morristech igniter if it becomes a problem
  • Like 1
Whats wrong with the tune? I thought it was all sorted
I do not think it is sorted, the way the boost is dropping off, something is wrong. I did not have a chance to do another rirve this morning
Doing some other work and then getting a new full 98/E85 Flextune but only after everything checks out .
It will all be checked out Joey, there has to be an answer to this :)
If were mine I'd be going to JEM for future work, seen enough guys on here get results, I might even take the drive from QLD, hahah, nah too far..
Haha, yeah, that's too far, they say that Jez is pretty good , lets see what he can do :)
  • Like 3
Everyone talking about this response down low - I bet he has a stack of it.
But he doesn't have any RPM to play with after that.
I am sorry it is not good enough in my book.
It was Pete's choice to have it this way. Don't be sorry because you don't like it.
Hey pete, got a vid of some 600hp GTR's , give you some motivation to get on the track and enjoy... lol...
Yeah, liked this. I have watched it before and always good for a second or third squiz :)
It does make you want to give it a run :thumbsup:
Yes it was my choice and do not regret it, maybe I was pissed off a few times, but when it is sorted it will go hard to 7500rpm but starts 2000rpm earlier, 900Nm is not too bad . So it is like someone else's car going to 9500rpm, but starting at 5500rpm. I like the idea my motor is not revving its head off.
when I first got the car it would go to 10,000rpm +, but :no: :no: Thanks.
Even with the crap I went/going through , it was worth it and it is not over yet, different tuner with a different approach may get more of what I want, if not and it runs freely to 7500 maybe 8000rpm , I will be more than satisfied and it will be more than I need,,,,,,,,,,,,,,,,,,,, but,,,,,,,,,,,,,,,,,,,,,,, I still want it, haha.
Not compared to the T78 in the 2.6 once it kicked in @ 6000rpm and then your head would fall off, so NO. I think after you have had a bigger turbo on, it ruins you a little as far as the initial boost feeling goes :/
Now it is more linear and feels very strong and starts to get going @ 3000rpm but still keeps you in the seat until you take your foot off...
I want to take it past 7000rpm. (my kids on holidays and very time consuming :) I will try to do that this morning just to see what happens, I thought it missed a little around 6500rpm but have not had a chance to confirm it yet?
Just took it to 8000rpm, went freely to 7500 and fell off to 8000, limited at 8000rpm , I was told.
So from 3000rpm to 7500 it is pretty good, so 4500rpm to play with , still wasted on me , but love it:)
It will be interesting to see what the dyno reading would have been if it could have held 24psi instead of dropping to 18.5 psi ??
I haven't yet needed/been able to to rev mine past 7000, maybe I'm driving too soft Pete!
Would be interesting, but I doubt it can flow much more air than it currently does at that rpm on a big capacity, hence why dump mod didn't change much?
I would not often take it past 6000rpm, just a test run to see what happened . Straight line diving, haha
See how it goes with the next tune
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
