How much boost/power can you go with 98ULP? I know my RB25 was on the limit at 280kw's, tuner said any more and the valves will start burning, but on E85 it was , "so where you wanna stop here?" , laughs all around it was ridiculous what numbers where being pumped out...
I had 445rwkw at 19psi on 98.
Have u had a car with a restricted turbine that caused boost to drop as peters did?
No issues with mine holding boost with a similar size turbine wheel.
And yours has got far more power than mine. That is how I expected my graph to look like, the psi is set and once it reaches the limit it remains there.
It is just strange that it drops off before it reaches the 6000rpm where I had the previous problem, but I do not know enough to make a statement, just an observation. This does not mean I am right :/
Also it is not as rich as it was every other time I had a tune , maybe it was a motor safety thing?
Going off the Dyno readings the PSI is dropping off at 150kph, tested it and at 150kph it is 4500rpm in 5th gear. That seems a bit early for it to start to taper off, well to me but I know very little about the workings of turbos/cars etc ??? Oh, and women :yes:
Edited by Nismo 3.2ish
Like you said earlier. You are going round in circles.
If CRD are not answering you then we can only presume that it is due to them not wanting to instead of them not knowing.
And lastly, just take it to someone else if you're not happy. Or are you happy? If you are then just leave the thing.
  • Like 2
Maybe because you said you didn't care about peak power just response they didn't bother making it hold boost.
I do find it hard to believe that they trialled various camshafts for some reason, but never made it hold boost...
I am not going in circles with what I said, I tested it today to see exactly what RPM the boost started to drop off , now I know and now you know :)
Dont want to know, dont read the shit :)
Take car to Jez
End thread
That is not the end, have to see what happens after it comes back from Jez, I will post the results.
You can all have a laugh at my whinging about the results if it is not better than it was and I will go away with my tail between my legs, THEN , end of thread :yes: :yes:
Similar turbine wheel size, my point being it should hold boost unless they tuned the boost controller to do that or compressor is out of flow which it shouldnt be
Not if there is that much back pressure that it cracks the gate open. But anyway we will see I suppose. Based on everything that has been said it points to the turbo IMHO. But who knows. But most of the time these issue seem to get solved with a bigger turbo. We all have theories, if I am wrong then I have learned something. Edited by XGTRX
  • Like 1
Maybe Ben, got one of the SAU blokes coming up tomorrow and want him to take it for a run and see what he thinks..
I go for a drive most days and love it, went this morning to check out the rpm to kph as it is not displayed and I did not notice the PSI drop off up to 6000rpm, just want to know why, got a few different opinions but it seems my push for answers annoys some blokes :)
Oh, and the only thing I have ever put shit on my X builder was for, NON COMMUNICATION !!!!!!!!!!!!!! and they are like that to the end!!!!!!!!!! hate it :(
You know what I do if I do not like a thread, I do not read it, if no one is interested it dies without being shut down, simple :/
  • Like 1
Ive read most of this thead, but i wouldnt be suprised they made the boost drop off to stop your missfiring issues
Looking forward to seeing further development with a different tuner. Lack of communication is quite frustrating
Get a life Mick,haha
I just cannot help think the same and could be 100% wrong, but the psi dropping from 4500rpm ,fark it only just spooled up, think it would hit 6500rpm before taking a nose dive ?
When I get the next tune maybe I will not even get the same result, it might be 350 - 360awkw, I do not care as long as the top end lose goes down to where I can play :)
Top setting was 22psi before this tune. But running on 22psi it went tits up at around 6000rpm.
Now it went to 24psi @ 4500rpm before it tapered off to 18.5 @ 7000 ( I think the 381.7 kw was around 7k , the private road I used would not let me go to 7k in 5th gear, just squeezed in 4500rpm, too short) Not sure if it is actually set at 24psi, just going off what I can see on the dyno chart before it dropped off.
There is no harm in having a guess at what is going on here and in about a month there might be some answers, could be better, or worse ??????
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
