How much boost/power can you go with 98ULP? I know my RB25 was on the limit at 280kw's, tuner said any more and the valves will start burning, but on E85 it was , "so where you wanna stop here?" , laughs all around it was ridiculous what numbers where being pumped out...
I had 445rwkw at 19psi on 98.
Have u had a car with a restricted turbine that caused boost to drop as peters did?
No issues with mine holding boost with a similar size turbine wheel.
And yours has got far more power than mine. That is how I expected my graph to look like, the psi is set and once it reaches the limit it remains there.
It is just strange that it drops off before it reaches the 6000rpm where I had the previous problem, but I do not know enough to make a statement, just an observation. This does not mean I am right :/
Also it is not as rich as it was every other time I had a tune , maybe it was a motor safety thing?
Going off the Dyno readings the PSI is dropping off at 150kph, tested it and at 150kph it is 4500rpm in 5th gear. That seems a bit early for it to start to taper off, well to me but I know very little about the workings of turbos/cars etc ??? Oh, and women :yes:
Edited by Nismo 3.2ish
Like you said earlier. You are going round in circles.
If CRD are not answering you then we can only presume that it is due to them not wanting to instead of them not knowing.
And lastly, just take it to someone else if you're not happy. Or are you happy? If you are then just leave the thing.
  • Like 2
Maybe because you said you didn't care about peak power just response they didn't bother making it hold boost.
I do find it hard to believe that they trialled various camshafts for some reason, but never made it hold boost...
I am not going in circles with what I said, I tested it today to see exactly what RPM the boost started to drop off , now I know and now you know :)
Dont want to know, dont read the shit :)
Take car to Jez
End thread
That is not the end, have to see what happens after it comes back from Jez, I will post the results.
You can all have a laugh at my whinging about the results if it is not better than it was and I will go away with my tail between my legs, THEN , end of thread :yes: :yes:
Similar turbine wheel size, my point being it should hold boost unless they tuned the boost controller to do that or compressor is out of flow which it shouldnt be
Not if there is that much back pressure that it cracks the gate open. But anyway we will see I suppose. Based on everything that has been said it points to the turbo IMHO. But who knows. But most of the time these issue seem to get solved with a bigger turbo. We all have theories, if I am wrong then I have learned something. Edited by XGTRX
  • Like 1
Maybe Ben, got one of the SAU blokes coming up tomorrow and want him to take it for a run and see what he thinks..
I go for a drive most days and love it, went this morning to check out the rpm to kph as it is not displayed and I did not notice the PSI drop off up to 6000rpm, just want to know why, got a few different opinions but it seems my push for answers annoys some blokes :)
Oh, and the only thing I have ever put shit on my X builder was for, NON COMMUNICATION !!!!!!!!!!!!!! and they are like that to the end!!!!!!!!!! hate it :(
You know what I do if I do not like a thread, I do not read it, if no one is interested it dies without being shut down, simple :/
  • Like 1
Ive read most of this thead, but i wouldnt be suprised they made the boost drop off to stop your missfiring issues
Looking forward to seeing further development with a different tuner. Lack of communication is quite frustrating
Get a life Mick,haha
I just cannot help think the same and could be 100% wrong, but the psi dropping from 4500rpm ,fark it only just spooled up, think it would hit 6500rpm before taking a nose dive ?
When I get the next tune maybe I will not even get the same result, it might be 350 - 360awkw, I do not care as long as the top end lose goes down to where I can play :)
Top setting was 22psi before this tune. But running on 22psi it went tits up at around 6000rpm.
Now it went to 24psi @ 4500rpm before it tapered off to 18.5 @ 7000 ( I think the 381.7 kw was around 7k , the private road I used would not let me go to 7k in 5th gear, just squeezed in 4500rpm, too short) Not sure if it is actually set at 24psi, just going off what I can see on the dyno chart before it dropped off.
There is no harm in having a guess at what is going on here and in about a month there might be some answers, could be better, or worse ??????
    • We are literally just kids stuck in an adult's body with bills and mortgages to pay 🥲
    • Behrman is great quality stuff. My 34 has some serious clouding as well but I’m too nervous to try and replace the glass myself so I haven’t bought them yet.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
