Best mod i did was removing boot mounted twin 044 surge tank setup and replacing it with twin nismo intanks. No noise no smell operated like a factory fuel system.
Not worried about the noise , the Walbro is pretty quiet and they are intank ,If there is smell problem , there will be a surge tank for sale :)
Steve , any petrol smell with the Nuke ???
Thanks Steve, I could not find very much info on the Nuke Surge Tank but they looked pretty well made and using the Walbros was a plus.
Did you mount yours in the boot ?
Yep in the boot. No fumes as yet
Aeroflow 250 series black braided Teflon hose or similar is the product to use.
Right side puts the surge tank in front of the Attessa reservoir. If you don't mind having to remove the surge tank to check the reservoir, then great.
Thanks
I think I will go the drivers side, depending on the size I might not have to move it to check the reservoir. I think when it arrives it will give us a better idea.
The other side has the jack and tools and allows a bit more luggage space. Sort of wish I put it under the car and if I have any problems that is what I will do.
Mine is in a r30 and its on the right side with Teflon braid. I used bulkhead fillings through the floor
not that it will make any difference but what did the Teflon braided cost for the job, just wondering the price difference between that and a cheaper alternative ?
Still going in tomorrow Pete?
Yes Mark , leave here around 4am , get a train and a bus back home and it just about drops me at my door, only $35 as to $400 getting to and from the Sydney shop , even though I flew to Sydney 1 Hr, 40min to the airport , they want you there an hour before the flight, 2 trains and get picked up at the station , it is about the same time :)
After he drops me off I think he will do a dyno run to have a look and be able to have a back to back comparison after the work is done.
Jez did mine and I can't smell shit. it's in the boot taking up space
Can still fit a few slabs of beer in so all good
He is going to use quality lines and I am sure it will be no problem
haha, couple of slabs would get you through Saturday :)
