Lets hear it, maybe it is something I do not know and can stuff it in there somewhere :)
Where can I see your build?
http://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/
Ran into some other problems today , so that should make you happy :cheers:
What problems Pete?
There have been a few things, the latest V V V
My manifold could be used for a colander there are so many cracks and holes in it, sounds like a whorehouse,lol
Going to put a 6 boost manifold on.
Should help not having all of those holes and cracks hurting response and power as the exhaust pulse/pressure is escaping before it reaches the turbine
Was your current swiss cheese manifold a single gate Pete?
Is Jez going to put a twin wastegate manifold on it?
You will pick up some nice response gains having a proper twin scroll setup. I cant believe that those clowns at that last "workshop" didnt see that!
Also surprised Mick didn't pick up on the leaks as ive seen the pics and its completely f**ked!
I'm a little suprised also and disappointed in myself about it, but then I was not listening for it and at idle it wasn't noticeable
But the then CRD didn't pick it and either did Jez straight away :/
Having a manifold that doesn't leak like a seeve will help heaps everywhere in the rev range
Thing is though you weren't looking at it on an Engine stand Mick you also didn't have your head under the bonnet while it was being flogged on the dyno (which clearly they didn't either as they would've heard the detonation and the exhaust leaks) They woulda had that thing on and off and woulda been holding the f**ker!
Thats really poor form from those guys! Shows their lack of care!
You can see clear as day where the gases have been pissing out of it.
The number of cracks in it wouldn't of happened since Pete has had the car. The thing has been a mess for quite a while.
I hope everyone that reads this thread takes their money and business elsewhere and tells all their mates to do the same!
Edited by Mick_o
  • Like 4
Thing is though you weren't looking at it on an Engine stand Mick you also didn't have your head under the bonnet while it was being flogged on the dyno (which clearly they didn't either as they would've heard the detonation and the exhaust leaks) They woulda had that thing on and off and woulda been holding the thing!
Piss poor!
Were CRD looking at it on an engine stand? My guess is no, they weren't looking for hard to find cracks, as Jez didnt find them for 2weeks? Plus its all second hand parts and it went back to get the tune fixed, not the engine out?
There's nothing saying the cracks were there when the used part went back on.
We all know cheap manifolds, even non cheap tomei manifolds crack.
It shouldnt matter if they were "looking" for it or not.
when it ran like it did they should have picked it up - detonation, cracked manifold.
Poor workmanship and unprofessional service when getting back to the owner.
Horrible.
Jez obviously thought something else was wrong and looked. That is good work.
Horrible.
What detonation? Has the engine been pulled down?
Lol not sure if serious? You do realise that CRD built the engine right?
Piss poor on their behalf. Glad it's on to Jez and he has found some things.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
