Lets hear it, maybe it is something I do not know and can stuff it in there somewhere :)
Where can I see your build?
http://www.sau.com.au/forums/topic/378971-the-build-of-the-beast/
Ran into some other problems today , so that should make you happy :cheers:
What problems Pete?
There have been a few things, the latest V V V
My manifold could be used for a colander there are so many cracks and holes in it, sounds like a whorehouse,lol
Going to put a 6 boost manifold on.
Should help not having all of those holes and cracks hurting response and power as the exhaust pulse/pressure is escaping before it reaches the turbine
Was your current swiss cheese manifold a single gate Pete?
Is Jez going to put a twin wastegate manifold on it?
You will pick up some nice response gains having a proper twin scroll setup. I cant believe that those clowns at that last "workshop" didnt see that!
Also surprised Mick didn't pick up on the leaks as ive seen the pics and its completely f**ked!
I'm a little suprised also and disappointed in myself about it, but then I was not listening for it and at idle it wasn't noticeable
But the then CRD didn't pick it and either did Jez straight away :/
Having a manifold that doesn't leak like a seeve will help heaps everywhere in the rev range
Thing is though you weren't looking at it on an Engine stand Mick you also didn't have your head under the bonnet while it was being flogged on the dyno (which clearly they didn't either as they would've heard the detonation and the exhaust leaks) They woulda had that thing on and off and woulda been holding the f**ker!
Thats really poor form from those guys! Shows their lack of care!
You can see clear as day where the gases have been pissing out of it.
The number of cracks in it wouldn't of happened since Pete has had the car. The thing has been a mess for quite a while.
I hope everyone that reads this thread takes their money and business elsewhere and tells all their mates to do the same!
Edited by Mick_o
  • Like 4
Thing is though you weren't looking at it on an Engine stand Mick you also didn't have your head under the bonnet while it was being flogged on the dyno (which clearly they didn't either as they would've heard the detonation and the exhaust leaks) They woulda had that thing on and off and woulda been holding the thing!
Piss poor!
Were CRD looking at it on an engine stand? My guess is no, they weren't looking for hard to find cracks, as Jez didnt find them for 2weeks? Plus its all second hand parts and it went back to get the tune fixed, not the engine out?
There's nothing saying the cracks were there when the used part went back on.
We all know cheap manifolds, even non cheap tomei manifolds crack.
It shouldnt matter if they were "looking" for it or not.
when it ran like it did they should have picked it up - detonation, cracked manifold.
Poor workmanship and unprofessional service when getting back to the owner.
Horrible.
Jez obviously thought something else was wrong and looked. That is good work.
Horrible.
What detonation? Has the engine been pulled down?
Lol not sure if serious? You do realise that CRD built the engine right?
Piss poor on their behalf. Glad it's on to Jez and he has found some things.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
