Best that night was 11.1@132mph with a 2.1 60" :(
Car weighed in at 1682kgs without me and I'm 108kgs
Car has gone 10.8 @132mph with a 1.7 60"
When you feel the front moving sideways as well you can be fairly sure the 4WD does work, eventually lol, it still needs more bleeding, it is just been a PITA this time for some reason :/
I would definitely be bleeding out ur 4wd, 2.1 60' is rwd territory not 4wd, something is not right.
Mine barely spins in 2nd on prepped track, and the only way it will spin in 3rd is with 4wd turned off.
How much power on ur 10.8second run?
You end up spending more time fighting the car to keep it straight then putting down good lap times
I went to the drags last week for shits and giggles and it had no tractions 1st 2nd and most of 3rd on 24psi which is about 440kws on a prepped track, now imagine that every time you come out of a corner and try to put the power down one a surface that isn't prepped for extra traction
Can be done don't get me wrong it's just not a fun experience if you are looking for a good lap time, 4WD skids then it is awesome fun, at 380kw I was drifting the fishhook in 4WD when it finally started to work ( not bleed completely so 4WD takes its sweet arse time to activate) at wakefield while peddling it
If that's the case, why are you going for turbos that will do 500 kW or more?
  • Like 1
It was a cold night on 295/30/18 Z221s which I just could not get heat into hence why I am putting the 265s on, there is a film clip of it launching and spinning the fronts so they are working they are just taking longer then they should to activate
It was definitely spinning all 4 through 2nd and most of 3rd as it was snaking pretty big all the way through those gears
i
Is that in a r32?
I would look at your 4wd system, i ran 10.6 sec @ 136mph on 235 federal tyres, only traction issues are off the line in 1st gear.
  • Like 1
R34, I'm going to bleed it again before wednesday but when I get back from ringwood this weekend the OS88 will be going in and I'll have to do it again
I think the problem is more the tyres and how cold the track was, stone cold semis don't work so good, I also don't have a 2WD switch so no way of getting any heat into them :/
My 34 is 280kg heavier then my 32 :/
Are both ur cars rb30?
Arent the r34 supposed to be faster reacting 4wd systems with more preload?
Maybe try some street tyres instead of the semis, i had no luck with bridgstone semis
Only 34 has 30, 32 is still stock motor stock turbos
Faster computer but still need the system to be bleed correctly to work properly
I only have 275/35/19 RS-3s as street tyres which have a much bigger diameter or two sets of semis
I'm waiting for the 265 semis to wear out so I can fit the 265/35/18 AD08Rs to those rims
You seen GTRNUR's results in the build thread pete, seems relevent to your situation some what, a 6466 that was maxing out with 98 at around 380ish , but he's getting full boost much earlier than your 4000rpm goal ...
What tyre pressure did u run?
30 rear 32 front, it is what you have to run with these tyres to get even contact across the tread
Wait whos thread is this? Lol
Pete....... Where are you? ;)
We will see 100 pages one way or another dam it :rant: lol
  • Like 1
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
