I will ask, maybe it is the old one just sitting there, I do not think he would use a gasket that is not good enough for the job ?
Seen enough of them leak to not use them.
In a perfect world if the manifold flange and the turbo housing are dead flat then single layer one would be fine......but it is not always a perfect world.
I doubt he would something that would stuff the job to save a $ , that does not seem to be what he does , if he did use the gasket I would say it is dead flat :)
  • Like 1
The 6 Boobs mani looks the biz.
Is that a single layer gasket sitting on there Pete......? Tell however speced that to stop being a cheap bastard and put a good multi layer one on like a Permaseal.
He uses Silicone for the gasket
Almost like he has done one or two before
Spot on, guess it is that RTV Silicone :)
He is going slowly through my car and sorting out what he thinks will get the best results and I cannot wait to see / feel the difference the changes make.
People around here are acting like Jez is a noob.
Such noobs
Once he told me he was using Silicone I had to Google it, I did not know they had a Silicone that could handle that much heat, so learnt a little more today :)
So manifold is in and looking pretty.
Turbo going on?
Turn the wick up yet?
Should be on the Dyno very soon
The wick up, I hope so , especially in the response zone, E85 and the boost controller should let me turn it up on demand :yes: But I cannot use the top end power now , well a little, unless I start going to Sydney and have some fun on track days for dummies :cheers:
"You cannot use the top end power"?
You can it just may get you into some trouble.
It is easy enough to get into enough trouble with an old VW :)
But these Rs can get you into BIGGER trouble :spank:
Edited by Nismo 3.2ish
Such noobs
I wouldn't know Jez from a bar of soap, but if he is using shit products like cheap single layer gaskets on a high end build like this I thought I would comment.
......sorry I thought this was a forum?
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
