This is on 98 Pump
Here is the overlay of the car as it arrived.
If i hold the car at 3300rpm under load i can get 20psi.
This dyno run is seeing 22psi at 3950rpm and revving to 7000rpm in 5th gear
The Pic is an overlay of the run he did when I dropped it off (green) and today (red)
Not sure when the E85 will be done?
  • Like 2
Thats a f**ken epic result Pete!
You're gunna be in for a shock now when you drive it on Petrol let alone E85 lol!
Expect near the 500kw zone on E85 mate.. Congrats and well done to Jezzabelle and the boys sorting out the horrible mess you had! Cant wait to hear your thoughts when you drive it now!
Edited by Mick_o
  • Like 1
Yeah Mate, I knew it was a heap of shit the way it was, and I think this proves it :nyaanyaa:
I think I might start using the seat belt now :woot:
Don't forget your adult diapers as well as that seat belt!
Yeah i always knew it was POS when i saw the dynosheet let alone your impressions of how it drove!
You wont want to get out of it now mate!
He changed the rear of the turbo Pete.
  On 13/08/2015 at 3:46 AM, XGTRX said:
So he changed the turbo rear? Good thinking
No, the PT6266 was on it all the time, it was not the PT6262 that was supposed to be ordered, this was the thing I said I would post at the end, but I waited for someone to see it on the Dyno Graph.
When I posted the pic of the 6Boost being installed I had an email from the old builder saying , oh you might notice the Turbo is a different model, I said yes it was noticed and he said that he told me about this when the build was being done, I said I think I would remember that, he said I might have been pissed, good call but that is something I would remember , well , I would think I would remember, hic hic
But all good as it is a better Turbo for the job on the 3.2 , but not for the 2.6
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
