no matter the details of this, most will look at it how it is, its was at CRD for a bloody long time, they built it so good on them for that but they didnt deliver the final result, and in alot of peoples minds that is what counts!! call it how it is... the JEZ kicked ass with it, you'll have some wobbly knees in the next week when you drop the hammer pete, so jealous right now...
  • Like 1
Well done Pete, great result!!!! Am looking forward to some vids :D
When I posted the pic of the 6Boost being installed I had an email from the old builder saying , oh you might notice the Turbo is a different model, I said yes it was noticed and he said that he told me about this when the build was being done, I said I think I would remember that, he said I might have been pissed, good call but that is something I would remember , well , I would think I would remember, hic hic
This does seem pretty weird I reckon. If they had already told you about the turbo, why bother writing you an email to "remind" you. Oh well, it's all done now, enjoy it for what it is :)
If most look a bit deeper the truth is quite obvious, you didn't have to be Nostradamus to worked it out 30 pages back. Nothing has changed in 15 years of forum garage battles. A shame really.
But what's important is Pete gets his car back and is happy with it.
I remember reading an article and an english guy built a RIPS RB30 in a R33 with a PPG Getrag 6Speed they detuned it to 700HP as the torque smashed the gearbox to peices after a launch down the strip.
Was on pump gas too.
So have fun hahahaha with that monster and that insane torque number. Think there are reasons AMG also electronically limit their torque numbers :P
You are right, they just bought the Turbo thing up AFTER I posted pics of the cracks in the manifold and 6boost, I was surprised to get an email from them,
Matters not, I have not stopped smiling since I got the Dynos and could see the car is running much better, even at my piss stops through the night I had a smile :yes:
Vids, what sort of vids can I do, Dyno tunes are boring , see if I can get some tyre action if my drive line and AD08Rs let me without leaving the box behind :bomb_ie:
Well , thanks, I think lol
I will see how it feels and go from there, it will be interesting to see how it feels to drive instead of looking at a Dyno graph, about 700rpm earlier full boost,so see if it gets it going.
The tractive effort/torque is 974Nm , peaking at 5250rpm
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
