Yeah that was both turbos on 20psi.
Picked Petes car up today and it drives ALOT nicer!
Unfortunately the weather in Sydney is crap so no chance of giving her a squirt. The 1 time i did stab it to about half throttle in 2nd gear  (on a dry ish patch of road) at 3600-3800 she was turning the 265 AD08's lol. Its definitely alot perkier than it was with the 6266!
I think with some seat time Pete is gunna love this this thing now!
54 minutes ago, Mitchee said:
Been following this since the beginning. Good on you for sticking with it.
2 years to the day since you started this thread!
Cheers mate,2 years to the day!, shit , it seems like 10 years, lol
There have been some funny posts , both positive and negative but that is what this modding your car is all about, what you want from your car and F everyone else, haha
1 hour ago, Piggaz said:
Here is as it came in PTE at 20 psi in 98 vs EFR at 20 psi on 98.
Red = EFR 8374/1.05 TS
Blue = PTE 6266/0.84 TS
The cars 6266 tune was off when it was dropped off and run for that base line test. There were other factors with the tune as well that I do not truly understand.
You will know on the weekend how it runs in comparison to how it did when I first picked it up from the original tune, you drove it!
As I understand it , I can run the car on 50/50 98 and 85 and not loose much performance,  it will still run around 437kw with plenty of grunt
I was in 2 cars with the 8374 , both had better throttle and transient response than mine with the 6266 , I have seen one of the dyno graphs and mine is  good in comparison. So if my car drives the equivalent to the other car with my graph, it will be mad
So I guess driving it is the real test and do not forget, the Dyno is a tuning tool as there are too many variances to take much notice of any of them, just a pretty picture :)
2 hours ago, fatz said:
3.2 at 20 psi nasty
though both would make more
You know whats in it Pete, "make more where ?" The turbo is close to maxed on the build , maybe 25kw ish, so , go BIG TURBO , it is a street car and defeats the purpose ??
It is built for running under 6000rpm . Turning wheels at 1/2 throttle in 2nd under 4000rpm seems tough enough
If I wanted 800 or 900 HP I would not have gone 9180 or something more laggy   ??
Anyway I am sure it will be great on the street, so :tongue:
Just to add something the Tuner said.
I would not read into the dyno response figures at low RPM too much as I had to run at a much higher ramp rate that I would like due to the torque splitting playing havoc on the dyno.  This is very common for GTR’s on dynos when the power output is very high.  The best comparison is to see how long it takes to reach x boost from x boost.  Not just RPM.  I can literally put the foot down and have boost on demand in your car with this turbo.  It is very sharp.
Ignoring how a dyno reads and looking at just sheer airflow and engine efficiency, the odds are the car is making >800hp @ crank when the EFR8374 hits close to the 120,000rpm peak that Scotty limited the turbo at ;)
Dyno is just a tuning tool - the Gen2 6266 is well known in terms of potential, both from this car as well as on others, the 8374's abilities are also pretty well known.  The engine is a healthy 3.2litre, running over 20psi of boost and the turbo is spinning at 120,000rpm peak (by choice) and is using ethanol blended fuel.   It's fairly safe to say that the dyno number is academic, at a pressure ratio of 2.5 and 120,000rpm shaft speed that turbo is moving >75lb/min of air.  Even on petrol that is going to be >750hp @ crank if all is running well, let alone if he gets E85 in the tank.
There is every possibility the exact same setup on a different dyno with a different ramp rate would make more - even the same setup run "on kill" would on the same dyno and setup.
I am very much looking forward to real world impressions!
Edited by Lithium
4 hours ago, Scooby32 said:
Seat of the pants impressions compared to the 6266 Pete?
Mid range seems a bit doughey ? :10_wink:
The 8374 smoked the 6266.. 6266 felt like it "hit harder" probably because it was a solid 400+rpm off the pace in early gears compared to the EFR!
The EFR feels alot more linear in its delivery. But thats just because it has more torque everywhere else than it did before.
I done 2 other 1st - 4th gear pulls before that little clip that i made and pushed it a little harder up to 7500 and she doesn't let off!
The thing i like most is how the EFR's respond to throttle.
For example i was in 4th gear cruising at roughly 2800rpm bent the big toe down a bit and by 3000 its looking to start hauling again.
As you can see in the clip short shifting it is a breeze and it just snaps back to life instantly.
Pretty sure if you tromped this thing and short shifted it at 5000rpm it would boot you straight back up the ass as the needle snaps straight toward redline.
This type of car might not suit everyones style but i can tell you not much would touch this thing on the street.
Its a pretty special car & i feel very privileged to get a steer of such a beast! (ESPECIALLY BEFORE THE OWNER)
??? Pete!
I bet that wrinkly ass is in bed while im typing this post so only 1 more sleep and we will have her home for ya mate!
Make sure our piss is cold and your recycle bin is empty for when we get there because this calls for a celebration! ?
Edited by Mick_o
Because edit
  • Like 1
??? Pete!
Hahaha, funny Mick, but my wrinkled arse is up typing this while yours is sound asleep and I have read some other threads I follow already!
I think you have driven the car enough to make those statements , just watching the needle head north from 3000rpm is a fair indication that what you said is on the mark. I am looking forward to moving the seat forward and giving it a run as soon as you get here , you two can grab a beer and chill .
I bought an ATS triple plate clutch as a back up, might swap it over and sell the Coopermix C-Spec twin before I do damage to it , it has been great ?
Bin is empty, beer is cold and Bourbon is aging as I type  , look forward to see you mad f*****ers :)
  • Like 3
