37 minutes ago, Looney_Head said:
awesome result Pete. now time for some videos of it running.
Yeah mate , they did a good job finishing off the last of my list. Would have been a lot easier and cheaper if I knew what I was doing when I started it, lol
not much on vids and most are boring from inside the car,  there is nowhere to hide in a small town, you definitely do not attention ?
Like Paul said, the torque steer is pretty bad , I am hoping it can be something simple that causes most of it,  like uneven tyre pressure. The car was in the shop for 4 months and I hadn't touched them since I put the new tyres on some months before it went into the shop , how slack is that , LOL
So tomorrow I will pump them up and see how it drives under some power and hope for the best. If that doesn't fix it or make it more manageable, an alignment is next and work from there
Have all new bushes and the car drives straight until you bash it hard , otherwise it is OK under power.
Anyone had this problem and fixed it ?
  • 2 months later...
Forgot  to finish off
After being in the shop for so long the tyres were all different pressures, pumped them up and it went straight and hard ,silly me :/529409778_Halftune.thumb.JPG.64a907973876c20e0c5f4eb69e28823a.JPG,
Had the car in just to touch up the tune,  picked up a bit more under 4250 rpm
Finally able to say this "THE END"!
11 hours ago, Ben C34 said:
That will definitely be fun!
Yeah Ben , a lot of blokes put shit on me for chasing response in this sort of high revving car , I had no option as I really liked the car , not the setup.
Had my early morning heart starter 110 klm  drive and my first drive at 77 LOL., that adrenaline is good shit ,  set for the day now :)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
